BIKELAND > FORUMS > ZX-14.com > Thread: 2012-13 ZX14 rods work in 09 ZX14? NEW TOPIC NEW POLL POST REPLY
Big_T112
posted August 20, 2013 02:33 PM
Found a set of new take out rods from a 12 model. will they work in my 09? I see they use the same connecting rod bearings.
Viper
posted August 21, 2013 03:11 AM
2012 and 13 zx14 rods are longer than the 06-11 rods
2012 ZX14R SE
quick6
posted August 22, 2013 06:55 AM
they might work with some stroker pistons. i think the new rods are around 3mm longer. but why replace stock rods with more stock rods? are they supposed to be stronger or am i missing something here.
2006 zx14, fully dressed and sliding(Charlie Sheen)
MotoCycho
posted August 23, 2013 02:33 PM
Don't all the after market beefy rods weight more? So unless you are doing a turbo or bigger bore and stroke etc.. more weight in your rotating mass = slower revving than stock without the additional comp or boost etc... Yes I know the point is to get more displacement run higher compression etc.. using stock 14r rods might be a easy way to get a lighter weight faster revving stock bore motor... but you'd need the stroked crank also, right? Would sure like to know all the details if anyone is doing this or has done. The 14r of course has more stroke.. I'd bet the challenges are more than just the rods... like cylinder length etc. Anyway.. sure wanna hear details about it from anyone going there.
quikgix
posted August 27, 2013 08:00 PM
Why are the 2012-12 rods longer?
1352cc 8.39@159mph on motor cant wait to spray this bitch
Viper
posted August 28, 2013 02:20 AM
rods are 3mm longer the case is 5mm taller. With the extra 2mm of the crank and the 3mm of the rod that equals to the height of the case. Better rod to stroke ratio and it still uses the same after market pistons. The 2012 /13 rods are supposed to be beefier on the ends.
2012 ZX14R SE
0.27426886558533 seconds processing time
