BIKELAND > FORUMS > ZX-14.com > Thread: HELP!! Engine making noise, battery losing volts and overheating NEW TOPIC NEW POLL POST REPLY
dragbikercr
posted April 15, 2013 07:50 AM
So I put a crank (stock) in over the winter and new valve springs, Carpenter springs. Since I reinstalled the engine I would start it in the garage and did a couple heat cycles. After shutting it down it would boil over out of the overflow tank, both times. I thought it was vapor bound, air in the system. So then I took it to the track.... I noticed it would still overheat, also I noticed a noise started up. The noise sounded like a fan was running and hitting (but the fan was not running). It would only make noises on a twist of the throttle or on a launch then goes away. The hotter it got the louder it got. I then noticed the battery draining quick. Got the bike out of the trailer battery was 12.3 volts, after 3 runs it was down to 9.8. Bike wouldnt start. tried charging the battery, had 12.8 with charger on, tried starting it and will not even turn over. Any ideas what could be wrong?
No oil light on, noise does not sound like its in the engine, checked checked clutch basket, water pump and oil pump gear, all llok good. Im thinking something with the starter or alternator???? HELP!!!!!!!
joel787
posted April 15, 2013 09:32 AM
I would start with Head gasket and volt regulator
dragbikercr
posted April 15, 2013 10:34 AM
I dont think head gasket, no leaks, e.t. stayed the same as last year. voltage regulator could be part of the problem.
dragbikercr
posted April 15, 2013 10:35 AM
By the way this is a 2008, pretty much stock....
joel787
posted April 15, 2013 10:58 AM
The spilling might be a faulty rad cap i upgraded mine to a 20psi, or air in the system..if none of those then headgasket...does the bike sucks the overflow bottle back?
krexken
posted April 15, 2013 12:49 PM
I'd be pulling the alternator off for a look. Sounds really weird to have so many seemingly not related problems. Could a one way bearing on the starter drive be bad and keeping the starter engaged all the time?
dragbikercr
posted April 15, 2013 01:24 PM
I am going after the alternator in a couple hours, that would make sense. bolt could have broke or loosened and shifted the magnets or whatever causing a noise and then it would not charge correctly... At least im hoping!!!!
dragbikercr
posted April 15, 2013 01:25 PM
I also just put on the high pressure radiator cap last week.
1badzx12r
posted April 15, 2013 04:03 PM        Edited By: 1badzx12r on 16 Apr 2013 00:04
i had a miss shift so bad 1 day it spun the flywheel loose on the crankshaft .. bike would not charge ..
dragbikercr
posted April 16, 2013 02:48 AM
Opened up alternator cover and low and behold the flywheel loosened up and was just hanging on the crank. Found my problem!!! Thanks all for your comments.
shiphteey
posted April 23, 2013 06:45 AM
Get in line and believe what the mainstream media tells you to.
Welcome my son
Welcome
to the machiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiine
Gemini Motorcycles
zixxer14
Damn that was Quick
posted April 23, 2013 11:16 AM
Shipteey you need to slow down on those drugs, you're losing it there boy.
biggmoinc
posted April 23, 2013 12:00 PM
That's awesome troubleshooting help guys!!!!
biggmo@aol.com
Meangreen14
posted August 28, 2013 08:42 AM
What's up guys, I'm having a little problem with my voltage it's an 09 14 has new battery bu know the voltage went from 14.1 to 12.5 while I'm riding and at idol it's droping to 12-12.2?? Also have to keep it on battery tender or in a week it wount start... Any one have any ideas, is there a way to check the regulator.
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
Ozonkiller
posted August 28, 2013 05:52 PM
There is a very specific technique for installing the rotor. I strongly urge that you follow it. Make sure the taper is perfect, inside and out.
What did you find with the overheating?
Tom
0.26172685623169 seconds processing time
