BIKELAND > FORUMS > ZX-14.com > Thread: Help NEW TOPIC NEW POLL POST REPLY
sc1172
posted July 31, 2013 10:27 AM
Help
http://images2.snapfish.com/232323232%7Ffp54367%3Enu%3D32%3A8%3E2%3A%3B%3E%3B74%3EWSNRCG%3D393%3A%3B334%3A932%3Anu0mrj
After making a run thought I heard a top end noise. Heard the cam chain tensioners go bad and will make lots of noise. I replaced the stock tensioner with an ape unit and that was not the problem.
Drained oil again and looked fine. Took pan off and found a few aluminum shavings.
Found the metallic pieces from the picture in the oil pickup...any guesses what this is?
Is it pieces of the thrust washer that goes in the cases for the crank?
WARBIRD
posted August 01, 2013 07:03 AM        Edited By: WARBIRD on 1 Aug 2013 15:04
I'd Rather Be Roadracing.
0.24725699424744 seconds processing time
