BIKELAND > FORUMS > ZX-14.com > Thread: loosing power NEW TOPIC NEW POLL POST REPLY
jimjundt
posted July 21, 2013 05:59 AM
loosing power
Last weekend bike ran great . This weekend after third pass it started falling on its face about 9500 up . Seemed like after the 8thmile you could see and feel it the most 1/8th mile ets went from 6.08 to 6.18 1/4s went from 9.30s to 10.00s. I was thinking possible fuel pump have been running mr12.
jimjundt
cliffrandall
posted July 21, 2013 09:53 AM
If you haven't been flushing the MR12, it could be your injectors - the particals (you can actually see them in your funnel) in MR12 that provides all the octane protection and 'ozygenation power' also clogs your injectors. Try this, fill up with pump gas and run it thru on a spirited street/highway ride for 1/2 hr. Should clear it up the injectors. Don't leave MR series fuel in your tank for more than a weekend of racing.
Cliff
jimjundt
posted July 22, 2013 07:40 AM
thanks i will try that
jimjundt
MotoCycho
posted July 22, 2013 01:02 PM
I'd suspect clutch slippage first. Over heated, worn, wrapped etc. Assuming stock clutch of course.
jimjundt
posted July 26, 2013 06:57 PM
new clutch only has 20 passes on it
jimjundt
NINJA12
posted July 29, 2013 06:53 AM
Pull the oil pan inspect for gold.
hope you don't find any.
quikgix
posted August 07, 2013 11:24 AM
Weird I've been leaving MR12 in my fuel tank after I race and I don't street ride, I make sure the pump is fully submerged with fuel.
1352cc 8.39@159mph on motor cant wait to spray this bitch
jimjundt
posted September 01, 2013 06:49 PM
well finally found the problem pulled fuel pump and found fuel filter pluged with black crap not sure what it was . but was told by vp that it is from leaving fuel in tank for to long. only had it in from race to race drained it in the winter. now just have to find a new filter has anyone seen a place that sells them seperatly or just complete oem fuel pump setup!!!!
jimjundt
0.22149395942688 seconds processing time
