Zoom
posted July 12, 2013 09:03 PM
Power Commander or not?
Is it ok to run yoshimura trc full exhaust on 09 zx14 with only a k&n filter and no power commander? Will it run the same as the jardine rt 5 slip ons? Or is a pc absolutely needed with a full yosh system?
Seno
BANNED FOR LIFE!
posted July 12, 2013 10:51 PM
Edited By: Seno on 13 Jul 2013 06:52
Similar discussion here, might want to reach out to someone running your pipe & get feedback before & after
http://www.bikeland.org/board/viewthread.php?FID=27&TID=62254
Seno
BANNED FOR LIFE!
posted July 12, 2013 10:54 PM
Personally why bother with a full system & not get a good map. Then get block offs and I forget if your year is a good one to pull the flies on, but the search tool is your best friend.
BrucerZX14
posted July 13, 2013 07:44 AM
The norm is if you change one, no PC is needed. Change both and you do. It will go too lean. As lean as todays engines run, I'd put one on it even if I only changed the pipe.
miketmmns
posted July 13, 2013 09:08 AM
Power commander is cheap compared to rebuilding a motor. If your going to buy
a full exhaust why not maximize it? Just my 2 cents.
Zoom
posted July 13, 2013 11:35 AM
Seno, its a 09, I tried searching before I posted but no luck. Bruce u mean single or dual exhaust?
indynic
Lil Show, Lil Go
posted July 13, 2013 03:49 PM
Everybody is talking about lean conditions. Aren't all year zx14's stock maps rich as hell? My 06 only has 2% fuel added in the top of the rev range with a 40 shot of spray. And I still think its rich if the weather is not right.
I remember Brock complaining about this in his diaries as well.
But, either way, rich or lean, to maximize your gains you need a PC.....
LeoVinceZX14
Thankfully...its paid for...
posted July 18, 2013 03:14 AM
Edited By: LeoVinceZX14 on 18 Jul 2013 11:41
Zoom:
Consider it cheap insurance along with a good tune. As the previous posts point out, the stock mapping is a compromise. Kawasaki knows most owners will fit a pipe so the WOT mapping is a bit rich in OEM tune for that reason, particularly the 08' and newer gen 1 bikes.
I had an '07 prior to my '12 and the PC3 and custom mapping made a noticeable difference both up top @ WOT and more importantly, with mid-range throttle response. The bike also ran significantly..cooler after being tuned despite me being in Florida temps year round. Leaner tunes run hotter (good for emissions/cats which is why the factory does it)
Likely without it (a PC & tune) you could experience...both conditions, a bit rich at WOT and lean at light and medium % throttle (everyday...normal riding) where the OEM tune is done more for emissions (leaner) than max performance.
Lastly, for the record, my '12 is getting PC V and a custom tune in a couple weeks when my exhaust goes on because without that PC and tune..it would not be optimized for all the preceding reasons.
Good luck,
'12 14R SE
PC V
Custom map
BMC filter
Leo Vince 4-2-1 w/ carbon can
Sato frame sliders
Supersprox 42T
Cox radiator guard
DID 530 X-ring chain.
Zoom
posted July 18, 2013 07:54 AM
Thanks, I was told by jeffo to take flies out which i did yesterday, I was sent the wrong power commander 5 model 17-009 for the er6n I need the 17-012 for the zx14. Once I get the right power commander, I'll put on my full yosh trc. I thought about using the map on a flashed ecu, leovince what made u choose the PC over flashed ecu?
LeoVinceZX14
posted July 18, 2013 09:27 AM
Zoom:
Good question, actually I am doing...both on my '12. Re-flashing the ecu 1st, then installing exhaust, PC and having it custom tuned. With the fly's out you would definitely want it tuned for your local conditions as it would for sure be lean at low and moderate rpm's with the pipe installed. That said, Yoshimura is a good quality pipe so I expect you will be happy once you get the correct PC and have yours tuned for how you use your 14.
Good luck with it,
'12 14R SE
PC V
Custom map
BMC filter
Sato frame sliders
Supersprox 42T
Cox radiator guard
cliffrandall
posted July 18, 2013 01:56 PM
The value of a PC5 is not just added power, its added information. Every bike arrives slightly different (every 14 and every 12 etc.) as such, every set-up is in turn a different tune. The thing I enjoy the most about the PC5 (and all the add ons) is the learning experience it provides. As simple as 'on the stand' garage idle set-up, with your laptop connected and the PC5 reading out the real-time changes you can make, thru to full PC5 Auto Tune with a wideband screen on the fly, to map switching on juice, is really amazing and fascinating to the die-hard motor-head, of which I'm one.....The process gives you a better understanding of the 'art of motorcycle tuning' and takes away the "I wonder if I did this".......Once you understand the F/A cause and effect, it makes you stronger.
Cliff
Zoom
posted July 18, 2013 03:08 PM
I like how u put that cliff, a great explanation.
