BIKELAND > FORUMS > ZX-14.com > Thread: How to raise the shift light above 11K ? NEW TOPIC NEW POLL POST REPLY
1000imp
posted July 11, 2013 09:51 PM
I got Guhl Flash that has raised my shift rpm to 11500. Does anyone know how to change the shift light above 11k ? It just stops ?
Thanks in advance !!
Seno
BANNED FOR LIFE!
posted July 12, 2013 04:28 AM
Not sure what the stock maximum is but just hold down the SEL switch and once in factory setup you can raise it (if it will go higher than 11K). If not then it's time to add a shift light or question Guhl if there is any provision to raise the option on factory option. The factory light is ok, but I would rather have something larger & brighter. From my reading Raptor makes a nice product that is not a rip off. Good luck!
zx12mark
posted July 14, 2013 08:12 PM
I have my dyna shift minder and light set at 11,125.by the time it makes the push button shift its a little under 11500 i believe.I tried 11250 but it was tagging the limiter..
1000imp
posted July 18, 2013 04:58 PM
I guess i will just stick with 11k. It seemed to work good in Indy.
0.29325795173645 seconds processing time
