BIKELAND > FORUMS > ZX-14.com > Thread: speed sensor help asap!!! NEW TOPIC NEW POLL POST REPLY
dp0289
posted June 21, 2013 04:42 AM
Hey guys I only drag race so I'm not worried about street riding. I'm making my gearing 16/45 tonight and guy said my speedo will be off and make my bike hit the speed limiter. I don't want to grind down the nut and I don't have time to install a sleedo healer tonight.
Can I just unplug my sensor??
Could I just put a piece of tape over it so it doesn't read anything?
Do I even have to worry about it??
madnessracing
Vmax and Busa Beater
posted June 21, 2013 10:50 AM
Dont worry about it
Shorty's Performance
Team Madness Racing
quikgix
posted June 23, 2013 05:20 PM
I ground mine down. But since I had my ecu reflashed I put a new nut back on.
1352cc 8.39@159mph on motor cant wait to spray this bitch
06redzx14
posted June 23, 2013 07:01 PM
If you unplug it you'll get a fi code
Rook
posted June 23, 2013 09:27 PM        Edited By: Rook on 24 Jun 2013 05:28
A new sprocket nut will not cost you much at all. Might be a little tough removing the old one .
I had my Speedo healer short out on me once (from washing the bike). It plugs inline with the speed sensor lead connectors. The speedo went berzerk and I think that sent the bike into limp mode ...so my educated guess is you will have as more trouble DIY hacking your speed sensor than you would just installing a SHv4. It really is not hard at all. Lots easier than grinding the nut corners. ...as long as you can get your hands on a SH, should not take longer than 45 minutes to install. It is NOTHING like the nightmare of installing a PowerCommander.
MotoCycho
posted June 24, 2013 12:59 AM
...It is NOTHING like the nightmare of installing a PowerCommander.
You are kidding.. Right? What's so tough about it?
1badzx12r
posted June 24, 2013 03:59 AM
I can't say adding a pc work BUT
I say that adding a multi-hub and downloading the firmware is a chore . I've got into a habit of letting the DJ techs do it with live help . then when it takes them several times to get the firmware to take i'm glad I let them do it ..
Rook
posted June 24, 2013 04:47 AM        Edited By: Rook on 24 Jun 2013 12:47
Getting hands in there on the main wiring connectors. Getting the plugs apart. Lots of people have a heck of a time with that. The rest is not bad. A SH is just grab the 2 wires and click together. stick the SH somewhere dry. Follow directions to test and set speedo to -50% to disable TSL.
dp0289
posted June 27, 2013 03:15 AM
Anyone try just taking the sensor out of the sprocket cover? I didn't have any problems with a 45 tooth sprocket but I might be going to a 47 in the future for a better 60'.
BobC
posted June 27, 2013 05:01 AM
I heard about this done in 2006 on a bike that was being top-speed tested for a magazine, before the Speedo Healer or reflash was available. From what I remember It works for one run and then you get a warning light on the dash. I can't remember if the ecu goes into a fault mode but you then have to plug the sensor back in and recycle the ignition to re-set everything back to normal.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
dp0289
posted June 27, 2013 05:10 AM
Awesome! So I guess taping over the sensor would be the same thing then as pulling it out.
BobC
posted June 27, 2013 02:39 PM
No, you can't tape it over on the 2006 - 2011 ZX-14R, it a magnetic head which detects the corners on the countershaft nut. Just follow the lead away from the sprocket cover to the connector a few inches up and unplug it.
Stock wheelbase
0.24894499778748 seconds processing time
