BIKELAND > FORUMS > ZX-14.com > Thread: wheel swap NEW TOPIC NEW POLL POST REPLY
ninjawilk1
posted June 11, 2013 08:00 PM
wheel swap
i want to put a set of 07gxsr1000 wheels on my 06 14 where can i get spacers and what other mod will i have to make this work..
kawasakiman
posted June 12, 2013 05:36 AM
Your going to need to measure everything. I've never seen anyone do this swap. I'm sure someone has, just not sure of any of the specs.
Lou_ZX12R
One Day at a Time
posted June 12, 2013 03:05 PM
May i ask why? Do you have a set sitting around or are you looking to lose some wieght? If the later, i believe the 2012 14r rims are light e r than yours and should be a simpler swap process.
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
toledoUPSguy
An old guy with a new toy
posted June 12, 2013 07:02 PM
shane was trying to fit those in his epic build thread.
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
ninjawilk1
posted June 14, 2013 02:08 PM
yes i have a set sitting they are show chrome i just think it would be a clean look
kawasakiman
posted June 16, 2013 05:54 AM
What's show chrome?
Is that the same as Chrome?
carabuser
posted June 16, 2013 11:37 AM
Basic GOOD Chrome job: This is two coats of nickle (duplex nickle) over steel then chromed. The thickness of these layers is the main difference in these two specs PL1 and PL2. The chrome makes the nickle shine and seals it.
The other method is what is used on ""Show" Chrome" Before the nickle, there are two coats of copper. The copper is used as a leveling agent. It fills all the small flaws and pores of the steel. The copper coat may then be re polished. After the copper has leveled everything, the two coats of nickle (duplex nickle) are added for about the same shine results, but to a much more finished surface. The nickle is then sealed with the chromium layer. A show chrome piece gives a much deeper reflection because the surface below the nickle is basically smoother.
posted June 16, 2013 02:42 PM
Sounds like a lot of un needed weight.
joseph702
posted June 17, 2013 08:14 AM
Ya a by waight diff , but if ur going for looks it's the diffrence of spray bomb paint compared to house of kolor paint job .
serius blk
posted June 17, 2013 09:23 AM
I weighed some 2012 wheels thinking they were ligjter. The back was only 1lbs lighter than the gen 1 wheel. The front was the same. If u want 3 bar wheels the zx9 front wheel will work also. The 3 bar and zx10 wheels are close in weight. Thats alot easier to do.
joseph702
posted June 17, 2013 10:54 AM
I love the zx10 06 07 wheels swap , IMO they look nice and save waight .
0.25773906707764 seconds processing time
