BIKELAND > FORUMS > ZX-14.com > Thread: PC3 Map Help NEW TOPIC NEW POLL POST REPLY
indynic
Lil Show, Lil Go
posted April 20, 2013 05:00 AM
PC3 Map Help
Does anyone have a good Pc3 Map for an 2006 ZX14 that you could email me?
Muzzy Full Exhaust
Flies Out
BMC Race Filter
I think my bike is running way too rich with my dynotune @ WOT.....I am also getting a huge stutter cruising along at between 3500-4000 rpms. My map shows -15 fuel in those ranges, so I wonder if its too lean through there....
I would like to see how my map compares to others. I am at about 800 feet of elevation.
bnkeller@hotmail.com
biggmoinc
posted April 20, 2013 04:52 PM
I believe that in those areas with flies out u need to be way rich,like +20 or so, not aany negative numbers in that range cause when flies are removed the bike is extremely lean between 2500-3500 or so, I actually have a muzzy exhaust but I'm currently using Brock's flies out street map for his pipe, thatis til its tuned, mright even try his track map n see if it increases mph, the map compared to muzzy map is way different n the 2-4000 range,
biggmo@aol.com
Newf14
2007 ZX1400
posted April 21, 2013 07:00 AM
U have the gearing changed on the bike?? I usually went on the powercommander site and tryed different maps....until I got my brocks pipe.
Newf14
indynic
Lil Show, Lil Go
posted April 21, 2013 07:07 AM
Gearing is stock front +5 in the back...sitting at about 67" with a Mac arm. I have had it dyno tuned for the spray.....but that map feels like its all over the place on the street and obviously way rich up top....
Newf14
2007 ZX1400
posted April 21, 2013 01:02 PM
The stutter you are getting is from the gear change IMO, my bike was fine till I put the front sprocket down a tooth and installed a speedo healer. I have had slipons and two brocks systems and all with different maps and the bike had the same stutter. Arn't NOS maps supposed to be rich up top?
Newf14
indynic
Lil Show, Lil Go
posted April 22, 2013 02:06 PM
My map is +21@ 100% throttle. But, where I am seeing the stutter is cruising @ 5% throttle in the 3500 to 4000 rpm range. My map is @ -15 @ 5% throttle input in that range.
Please explain how gearing change affects fueling....thanks
Newf14
2007 ZX1400
posted April 22, 2013 04:01 PM
Have a read this is what I am talking about..
http://www.bikeland.org/board/viewthread.php?FID=27&TID=69000&pagenumber=1
Newf14
0.2363748550415 seconds processing time
