BIKELAND > FORUMS > ZX-14.com > Thread: Yet another nitrous question! NEW TOPIC NEW POLL POST REPLY
GREYHOUNDMOSES
posted April 11, 2013 07:25 AM
For those fogging the airbox, where have you fitted the fogger nozzles?
In the rubber or plastic part of the ram air tubes? Top, bottom ,sides?
Any pictures would be great.
posted April 11, 2013 08:45 AM
look at adams spray bar, he hangs em above the velocity stacks and points em down the hole.
cliffrandall
posted April 11, 2013 05:29 PM
Muzzy does the same.
Cliff
06redzx14
posted April 11, 2013 06:16 PM
When I was fogging I had the foggers in the rubber tubes before the air filter
GREYHOUNDMOSES
posted April 12, 2013 09:02 AM
I've ruled out using a spray bar. I only plan on using nitrous a couple of times. I plan on attempting 200mph at a LSR event this year and I know I'll need a little help
After that, the nitrous will be taken off again so I'm looking for a simple install.
I know a few people just fog the airbox, but now I've come to drill the holes, I can't decide the best place to fit the ( twin ) nozzles without fouling the plastics?
Thanks Red. Did you fit them in the outer sides? There doesn't appear to be room on top.
MotoCycho
posted April 12, 2013 10:03 AM        Edited By: MotoCycho on 12 Apr 2013 18:04
You got a few options.. Ram air tubes, TB inspection covers or if you wanna get real crafty there are already a few holes going into the air box with various plugs. Tear everything off and look for yourself. That said, I'd get a spare set of TB inspection covers and drill some holes in those if the N2O was only a temp install. Getting the line up under the tank is a bit tricky cuz you only have a small gap. But its doable.
Good luck and let us know what you decide and feel free to share pictures.
0.30325794219971 seconds processing time
