BIKELAND > FORUMS > ZX-14.com > Thread: 520 pitch Rear Sprocket 530 Chain NEW TOPIC NEW POLL POST REPLY
riteristrob
posted April 02, 2013 05:47 PM
I have been running a 520 pitch rear sprocket on a Marchesini rear wheel with a stock front sprocket and 530 chain. The rear sprocket is getting some sharp teeth so I want to replace it. The chain is still within specs for stretch. I've heard that the chain should be replaced with a new sprocket.
Any truth to that rumor?
I plan on replacing the rear sprocket with a 530 pitch.
Is there any reason to replace both sprockets if the front is still in good shape?
What kind of longevity can I expect from a 520 set up on the street?
Any help is appreciated.
zx12mark
posted April 02, 2013 07:17 PM
How many miles you have on the set up.If you run it hard even the correct setup is shot around 15 - 20 k miles.And thats keeping it lubed all the time.
posted April 03, 2013 08:57 AM
Why run a 520 on the street?
Change both sprockets with chain.
riteristrob
posted April 06, 2013 07:11 PM
I bought a set of Marchesini wheels that were advertised as having 2400 miles on them. The 520 sprocket was on the rear wheel and I ran about another 2500 miles.
I think you're right about replacing both sprockets and chain. Might as well do it right with a 530 set up.
Thanks.
0.25907683372498 seconds processing time
