BIKELAND > FORUMS > ZX-14.com > Thread: Revenge from s1000rr NEW TOPIC NEW POLL POST REPLY
MehkoR
posted March 31, 2013 05:52 PM        Edited By: MehkoR on 1 Apr 2013 02:40
As you know i lost against bimmer very badly last season. This year i did better i think.
http://youtu.be/dkh9RrpoPdE
Last years situation was:
http://youtu.be/eodPTmnDtPs
This year i have annitori shifter / ecu reflash / different tire size(180/55/17)
ın Both videos i have brocks ctmeg
The bimmer is comlete stock and rider was 66kg ( i am 105kg)
I have more videos on tailcam but will take a bit to edit and upload.
posted March 31, 2013 06:24 PM
Pretty sad
are the zx14r detuned in the ecu for europe, cause that race last year is so sad .
Glad you redeamed yourself but we really shouldnt have to uncork a 1441 to match a 1000. yikes..
MehkoR
posted March 31, 2013 06:35 PM
I also tried against a stock zzr1400 and i am sure you can't believe your eyes. ı will upload as soon as possible.
posted March 31, 2013 06:43 PM
cool, Im sure you pounded on the zzr1400
is the euro ecu detuned on the 2012 zx14r?
MehkoR
posted March 31, 2013 07:12 PM
i have no idea! I made 2 dyno runs before and after ecu reflash
Before flash best max hp was 191.84
After flash best max hp is 196.41
But as you can see on the videos the difference on the road can't be the effect of +5hp
They said that it is the maximum hp they saw on a bike ever.
ı requested the graph but the operater is a bit rookie i think so i only have numbers
lietoome
posted April 01, 2013 12:24 AM
What map are you running? Has the 'rookie' touched your map?
MehkoR
posted April 01, 2013 02:16 AM
NO i uploaded in a car tuner shop. HE found the map from germany that his parthner made for a zzr1400 that has muzzy. Map is not perfect at the moment..may be i will return to the stock map and add a PCV for using Brocks MAP
MehkoR
posted April 01, 2013 02:23 AM
The car Tuner requested the graph to make a custom tune but as i said the dyno operator is a bit .....! and there is only 1 dyno in Ankara the other nearest dyno is 400km's away from me
my friends ZX6 measured 120hp in the away dyno and measured 107 at our dyno. Maybe it will give an idea
shawnski
posted April 01, 2013 03:47 AM        Edited By: shawnski on 1 Apr 2013 11:48
The BMW is over 100 pounds lighter, you weigh about 40 kg more than him.. you have a little advantage over HP.. and doing roll ons... What else will you expect.??
MehkoR
posted April 01, 2013 09:39 AM
did you watch the video i alreadt beat him
MehkoR
posted April 02, 2013 08:59 AM
the rest of the video
http://www.youtube.com/watch?v=Y1_-K52LN4M
what do you think if i put 43 sporket ???
1badzx12r
posted April 02, 2013 11:07 AM
43 porketts would be the shittz
posted April 02, 2013 06:36 PM
Give the little beamer another 400 or so cc's it may be ok
riaansh
posted April 03, 2013 12:03 PM
Well done man. the 1000rr is fast though, with him catching at some stage. You have a serious weight disadvantage with the bmw rider and bike weighing much less. Your top end is good with him not even contesting that.
Is the bmw still restricted at top end as you mentioned it's standard? I wonder what will happen when it's unrestricted.
MehkoR
posted April 04, 2013 04:06 AM
ı think BMW have no restrictions as default but not sure just read it on net
posted April 11, 2013 08:56 AM        Edited By: dubious on 11 Apr 2013 17:13
I thought the bmw is restricted top end due to rev limiter / gearing ?
carabuser
posted April 11, 2013 01:11 PM
RR is restricted until your 600 mile service, then they take off the restriction electronically, or you could do it with a GS-911 reader I think ?
CBninja
posted April 15, 2013 06:16 AM
My buddy has an s1000RR and they are not restricted. They top out at 197 with stock gearing though.
0.25502490997314 seconds processing time
