BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 and nitrous jets question NEW TOPIC NEW POLL POST REPLY
dragbikercr
posted February 20, 2013 12:23 PM
I have a 2008 ZX14, basically stock. Getting ready to put in Carpenter valve springs, just to clear that up.
My question is, with a Dynotune dry kit installed into the airbox and new aftermarket valve springs what is the biggest N2O jet I can safely use and not worry about the engine? Im only using this as an "oh shit" factor, not running it off the dead dig or on a progressive controller. Oh I also have the switch swapper installed with a nitrous map tied into the nitrous button which adds more fuel when I hit the button... Thanks
BlackMagic14
posted February 20, 2013 02:48 PM
Without pulling timing even with the springs 50-60 should be safe on pump gas. If you can pull some timing maybe 75 I wouldn't go any bigger than that
dragbikercr
posted February 21, 2013 10:00 AM
Ok thanks alot BlackMagic14.
loki 7
posted February 21, 2013 12:33 PM
With MRXO1 I ran 75 shot for two year without issue, APE valve springs, stock timing ,MPS spider nos.
0.24826216697693 seconds processing time
