posted February 08, 2013 06:41 AM
Did a single brake conversion on my class c motorhome
FYI was a little more work than I had anticipated but luckily I have a buddy who's mechanic. Pulled the driver's front as well as passenger rear so that way it stops straight. I knew I had to cut a little weight and this was the perfect place.
No idea why people haven't looked at this to trim fat before? Gotta go - headed up the Grapevine. Will post when I get back down the other side!
venomous_zx
2012 14r - low and long-
posted February 08, 2013 06:58 AM
lmao. i await in anticipation for your posting results
sensei
Bently
2012 14r In Blue and no Mods!
posted February 08, 2013 07:05 AM
Guessing you have dual wheel tire setup on the rear.I would remove one from each side
posted February 08, 2013 07:44 AM
quote: Guessing you have dual wheel tire setup on the rear.I would remove one from each side
YES.
Good point. Question is should I remove dual wheels from both sides or only from single brake side?
1badzx12r
posted February 08, 2013 08:41 AM
Edited By: 1badzx12r on 8 Feb 2013 16:42
they do it all the time on low clearance parking garages and overpasses . oak trees work good too..
get with the times buddy ..
don't forget the drive thru window overhang at wendy's
dcm 21
posted February 08, 2013 10:55 AM
You probably don';t need all that power.. I would probably remove one exhaust header(they're very heavy) and put block-off plates over the exhaust ports.Save weight-save gas!!
Beondwacko
posted February 08, 2013 11:02 AM
I was thinking that you may have gone the Fred Flintstone route and bought yourself some "hi friction" Ked's and just popped a hole in the drivers side floorboard.
Think of all the parasitic drag you could have reduced by removing the brakes at all 4 corners.
