BIKELAND > FORUMS > ZX-14.com > Thread: oil filter with sidewinder NEW TOPIC NEW POLL POST REPLY
LilJohn198807
FunSize
posted February 05, 2013 09:24 PM
Post up your pics please
posted February 06, 2013 02:57 AM
It depends on which sidewinder you have. I believe you must get a adaptor with the muzzy, but other ones you do not.
LilJohn198807
FunSize
posted February 06, 2013 02:52 PM
ok that is what I am trying to figuer out
LilJohn198807
FunSize
posted February 06, 2013 02:53 PM
I guess I should say I am putting it on a zx12 but since a 14 sidewinder works on a 12 I figuer i would ask for photos of both.
posted February 06, 2013 03:12 PM
What kind of exhaust is it?
quick6
posted February 06, 2013 06:09 PM
my v/h sidewinder hits the oil filter. had to get the relocator. but i have an adams bilet pan. not sure if it will clear stock pan or not.
2006 zx14, fully dressed and sliding(Charlie Sheen)
LilJohn198807
FunSize
posted February 06, 2013 08:22 PM
yeah I have a stock pan just cut. Going to buy a sidewinder proby used just trying to see which ones need and dont need a relocator so i know to order one or not when i buy a sidewinder. We have some new rules where i race this year so I have to have a side winder to keep it low like i want it
LilJohn198807
FunSize
posted February 06, 2013 08:23 PM
I had a full muzzy system on it, but sold it so it makes me buy a sidewinder.
posted February 07, 2013 02:26 AM
Get a Brock's. The filter is fine with it.
1badzx12r
posted February 07, 2013 03:52 AM        Edited By: 1badzx12r on 7 Feb 2013 12:03
i don't know about all brocks sidewinders but on my friends zx14 with a brocks sidewinder and flat pan . Even using a Yamaha filter(super short) the pipe tube don't give enough clearance to remove the oil filter. He has to remove the 4 bolts on the oil relocator and drop the whole assembly down to replace the filter. PITA ..He had a tsukigi previously and could get the filter off
maybe its the relocator problem http://store.schnitzracing.com/muzzys-oil-filter-adapter-kawasaki-zx14-06-13/ and he needs the side mount
LilJohn198807
FunSize
posted February 07, 2013 10:43 PM
thanks I will keep in mind
MotoCycho
posted February 08, 2013 02:30 AM
Just installed Brock's TiWinder and cut OEM pan. No oil filter clearance issues at all. Didn't have to even try that hard to get the filter on... lots of room without moving anything at all.
BrucerZX14
posted February 08, 2013 10:44 AM
If you go to a flat pan, the oil filter cooler is removed and a filter adapter is put in its place. This set up requires a Yamaha Raptor oil filter. Other option is the Orient Express one that is a 90 degree adapter. Should be able to use a standard filter with that one.
BrucerZX14
posted February 08, 2013 04:05 PM
Meant to say oil cooler. Not filter cooler.
posted February 09, 2013 12:03 PM
brocks and muzzy SWs for a 12 on a 12 fit fine with the oil cooler and oem filter, not sure about a 14 SW on a 12
LilJohn198807
FunSize
posted February 10, 2013 05:01 PM
ok
0.36024403572083 seconds processing time
