BIKELAND > FORUMS > ZX-14.com > Thread: How much compression? NEW TOPIC NEW POLL POST REPLY
Junkyard14
posted November 11, 2012 06:05 PM
Im looking to do a winter build. Keeping stock bore and stroke 1st gen.
Keeping in mind it will be a drag bike. How much compression can I run, and I will be running Q16?
Can I retain stock rods, how much squish is too much (.031), stock head bolts, ptv .035 in and. 055 exh, and what cam combo? Would the 2nd gen .366 in and 1 gen .355 in on exhaust work? I was thinking 15.5 to 1. Possible?
Junkyard14
posted November 11, 2012 08:05 PM
Can the engine gurus chime in
kaw now
posted November 11, 2012 10:53 PM        Edited By: kaw now on 12 Nov 2012 07:11
Maybe if you get a better avatar they will. Is that much compression going to help over say 13 to 1 and a good port job like the super sport ones.
Y2KZX12R
CompetitionCNC.com
posted November 12, 2012 02:59 AM
Junkyard, your options are to mill your head or put a set of pistons in if you want more compression. Forget Q16 you will only need mrx-01.
A port job, valve job, custom cams and your in the 210-225 hp range depending on how radical you want the engine.
Y2KZX12R
CompetitionCNC.com
Junkyard14
posted November 12, 2012 06:48 AM
So with 15.5 to 1 I can still run MRXO1? That would be great. The other question is how many compression points does every. 001 yield, and what kind of cam grinds do use or should I say lift numbers and duration. If its no secret . I've read that with high compression its optimal to keep low duration with a tad more lift?
Thanks for your input Jim, you do a great service guiding us in the right direction. I will be giving you a ringer soon after santa.
joseph702
posted November 12, 2012 07:43 PM
I'm pretty sure more compression over the norm it helps to have more duration in the cam.
Y2KZX12R
CompetitionCNC.com
posted November 13, 2012 04:07 AM
Yes mrx-01 is ok as long as your a/f is good.
As for milling and rise in CR... every chamber and engine design is different. You need to cc the chamber. The valve depth will effect it dramatically.
Joe is correct.... As a general rule as static compression rises it allows you to add duration to the intake cam and move the power band higher thus make more hp.
Y2KZX12R
CompetitionCNC.com
0.39479088783264 seconds processing time
