BIKELAND > FORUMS > ZX-14.com > Thread: LM2 data logger on ZX14 engine NEW TOPIC NEW POLL POST REPLY
johnbull
posted October 09, 2012 09:03 AM
Does anybody know where to take a good signal to log revs on the LM2 data logger on a ZX14 (2006/2007)
I am using a PC5 and I noticed that the software of the PC5 gives you a perfectly reliable tach display but on the LM2 I just cant get a smooth rev signal. I have tried taking it both from a coil and from an injector. I have also tried putting a variable potentiometer in between as the LM2 manual suggests under trouble shooting but rev signal still goes crazy.
Anyone know how to solve this?
John Bul Racing. Malta.
Adams Performance
Big Bore Long Stroke
posted October 09, 2012 09:15 AM
use your fuel injector wire. Try that and see if the signal is better
Garron Miller
Coby Adams
johnbull
posted October 09, 2012 09:30 AM
I have already tried the injector wire. Signal is still crazy.
1badzx12r
posted October 09, 2012 10:56 AM        Edited By: 1badzx12r on 9 Oct 2012 18:57
IDK if this will help but i always had to ground to the same source i was getting a signal from ..like if i used a injector wire i had to ground to same injector not to the battery or frame
Oz Booster
posted October 09, 2012 12:24 PM
Getting the same thing from a dl32 , erratic signal from the coil ,and rpm limits when from an injector at higher DC
1 badzx12r so you picked up on the power and inj switched gnd ??
i'm wondering if there is an induced voltage i am reading from the coil wires all running parrallel
and had considered twisting the wire pairs ??
Ozonkiller
posted October 09, 2012 08:42 PM
Cam position sensor. Been using it for years on my '06 with zero issues
CajunBoyz
posted October 10, 2012 01:07 AM
Is the CPS is where you saying to tap into for a clean rpm signal???
johnbull
posted October 10, 2012 01:15 AM
Will try cam position sensor and let you know how it goes. Tnx
tuusinii
posted October 10, 2012 03:17 AM
Do You have the newest firmware on Your LM2? Also adding capasitors and diode to the power connection helps. Also make sure You have good grounding.
Ozonkiller
posted October 10, 2012 01:05 PM
Yes, the cam position sensor can be used of an RPM signal. It will read half speed, but there are settings in the setup wher you can deal with that.
Oz Booster
posted October 10, 2012 01:30 PM
Sounds good, will try it too
johnbull
posted October 10, 2012 02:41 PM
Taken it from cam signal but still messed up.......now updated the LM2 firmware and it is now fine.
Thanks for all the suggestions
0.21320819854736 seconds processing time
