BIKELAND > FORUMS > ZX-14.com > Thread: im an idiot but maybe you can help anyway NEW TOPIC NEW POLL POST REPLY
toledoUPSguy
An old guy with a new toy
posted October 07, 2012 02:34 PM
Put on my alien head 2 any PCV today. Ended up taking off the radiator for the install. Put the red plug in and the pop went away. Then I installed the pcv. Lifted the tank up to try installing it under the seat. I know Rook showed how to do it but I must be a moron as I couldn't figure it out. So I followed the instructions to the "T". There is no way my pcv will lay flat on the side of the ram air tube, no biggie really. The problem that obviously makes me an idiot is that as soon as I turned the key I heard a crackle around the battery box and EVERYTHING is dead. Taking wife out to dinner and will deal with it later
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
venomous_zx
2012 14r - low and long-
posted October 07, 2012 02:48 PM
check your fuses. double check your wire connections. check to see if you touched frame with a bare wire anywhere.... check your battery cables.. maybe they got loose while your were installing.
sensei
toledoUPSguy
posted October 07, 2012 03:15 PM
Was that stinking frame ground connection. Steak always helps.
colt
if u aint first your last
posted October 07, 2012 03:43 PM
Fuse by battery under red cap same thing on mine everthing was dead I was hooking up hid and blue halos
venomous_zx
posted October 07, 2012 07:03 PM
i dont know why that frame ground wont work with pcv. i use it for my other electronics and it works fine.
sensei
toledoUPSguy
posted October 07, 2012 07:06 PM
glad we found out in the safety of the garage. didn't listen to the clues about the loose fairing bolts and found out the hard way. didn't take the advice about the frame ground and had and issue. there is a pattern here I need to correct.
0.26107001304626 seconds processing time
