BIKELAND > FORUMS > ZX-14.com > Thread: PCV install NEW TOPIC NEW POLL POST REPLY
toledoUPSguy
An old guy with a new toy
posted September 29, 2012 08:04 AM
PCV install
Is there anything special I need to know before installing the PCV? The instructions look pretty simple but sometimes things aren't what they seem.
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
venomous_zx
2012 14r - low and long-
posted September 29, 2012 09:22 AM
not really. its pretty easy. just a few hints for you though. that posi-tap the pcv comes with is neat. i would skin some of the wire to make sure it makes a good contact. i put the ground onto the frame like instructed but i ended up putting it directly to battery. i had a little problem with the ground when i out it onto the frame bolt.
sensei
runr2940
clown question, bro
posted September 29, 2012 11:22 AM
Thanks, I'm about to put mine on too...helpful info!
joel787
posted September 29, 2012 11:46 AM
+1...If the ground its not good the bike would die intermitently
toledoUPSguy
posted September 29, 2012 12:19 PM
are you mounting the unit on the left ram air tube like they show or somewhere more accessible?
joel787
posted September 29, 2012 03:17 PM
This one is for Under the seat ... Whatever u like
http://www.zx14ninjaforum.com/messages.cfm?threadid=CB3D3987-1372-66AE-3BE3B16BC01CC701
cliffrandall
posted September 29, 2012 03:28 PM
Here's what we do, plug the computer cable connection into the PC5 when you tuck it away and run the open end to a spot which you can easily access for map tuning (keep it dry). Otherwise you end up having to remove the bodywork everytime you want to fine tune - which can be often if you're changing fuel, doing air-flow mods or just fussy.
Cliff
venomous_zx
posted September 29, 2012 05:19 PM
i put mine on the left inside of the ram air tube. i coiled my usb cable and left it plugged into the pcv and covered the other end that goes into the laptop. i tucked it away just under the inside panel above the ram air tube. when i need to tune i just pull the cable and plug in. viola. i put a small bead of hot gl;ue around the pcv connection to help keep out moisture.
as far as the grounding on the pcv, my bike died while i was cruising around 85 on the expressway. i was lucky enough to get bike started after a few minutes and made it home to fix
sensei
toledoUPSguy
posted October 04, 2012 01:40 PM
http://www.powercommander.com/downloads/17-005/install/pcv/eng17-005.pdf
last page, temperature input connection. what am I supposed to do with that? I am really starting to think I'm the dumbest person on this forum but what a pain in the butt it is going to be to get that crank sensor plug unplugged.
FalldownPhil
CURMUDGEON
posted October 04, 2012 01:49 PM        Edited By: FalldownPhil on 4 Oct 2012 21:50
I ended up puting mine on the left ram air tube also. That came after discovering that it would not feed through to go behind the fuel tank, under the seat as on Gen 1's. Not saying it can't be done but it was not an easy fit on mine. The rest of it was pretty straight forward.
2012 ZX14R SE Super Pickle Cycle
venomous_zx
posted October 04, 2012 08:00 PM
the crank sensor is not that bad. it should be taped with electrical tape to another wire. i just wiggled it enough to have the tape slide and give enough slack to remove the connector. when you try to remove the crank sensor connector press the tab on the connector and at the same time pull down on it just enough so it wont lock back in place. as far as temp input wire you will not need that. you can leave that alone. that is the wire you would use if you wanted to add engine temperature function on the power commander
sensei
toledoUPSguy
posted October 07, 2012 06:36 PM
Glad I found out during the install that the frame ground doesn't work that great. I got it installed and turned the key to here a buzz and then absolutely nothing.
I tried for an hour (probably should have read Rook's post a few more times) and could not figure out how to route the wiring harness with the PCV under the seat.
Funny, the pictures on the pcv instructions show the unit laying flat along side the ram air tube. there is no way on God's green earth mine will lay flat in there.
venomous_zx
posted October 07, 2012 07:01 PM
just use zipties..
sensei
0.26049780845642 seconds processing time
