BIKELAND > FORUMS > ZX-14.com > Thread: MR12 and ignition NEW TOPIC NEW POLL POST REPLY
lazarosp
posted October 03, 2012 03:02 AM
MR12 and ignition
I am thinking to make a new map for my bike using MR12.
Do I need to go to dyno or just add some (?) fuel to the map I am now using?
Having this ignition map:
for 100 octane pump gas do I need to make a new timing map less agressive?
With this timing it made 210hp.
posted October 03, 2012 03:10 AM        Edited By: eklipse636 on 3 Oct 2012 12:36
If you are going to spend the money to run mr12, I would get a custom tune done.
shiphteey
posted October 03, 2012 03:39 AM
If you are going to spend the money to run mr9, I would get a custom tune done.
He said MR12, but yes, considering the costs associated with race fuel definately spend the money to tune it right.
A.
Gemini Motorcycles
posted October 03, 2012 04:37 AM
A.
Mr9... Mr12 ... same price.
RICH CRAFT 1
posted October 03, 2012 05:33 AM
I never go over 2° on pump gas, on something like MR 12. I would think either no timing advance, or 1° at the most. A lot of it also comes down to how hot is the motor, detonation or pre-ignition is sometimes started buy hot spots in the chamber. because of the low octane, the flashpoint is quicker, less timing is needed, on a high-octane fuel like C 16 for nitrous, it will hurt your horsepower without nitrous, because of its slow burn rate, this can be helped by moving the timing up if you're just running motor. I have heard of some guys, knocking the rods out on MR 12, probably because of hi timing, and hot lapping it.
Ken
Red 06 ZX14 RR
quikgix
posted October 04, 2012 06:33 AM
I pull 3-4 degrees of timing out of my bike with MR12
1352cc 8.39@159mph on motor cant wait to spray this bitch
0.50180411338806 seconds processing time
