BIKELAND > FORUMS > ZX-14.com > Thread: brake issue asap NEW TOPIC NEW POLL POST REPLY
colt
if u aint first your last
posted September 22, 2012 11:35 AM
brake issue asap
Ok I have had this 08 zx14 bout 2 months and I notice the back brake will lock some times when I apply med pressure has not been big deal I just use a lil of both brakes to slow her down . Long story short I let my buddy ride and he did not know bout breaks he was trying to slow down in front of the house and sleed 6 feet and when I wad going threw a turn today I taped the brake and the tire slides its not locking its sliding as if u were pushing all u could on the rear brake any help would be nice
samin
posted September 22, 2012 12:26 PM
maybe you need to change fluids and pads + clean the rotator.
*Who's General Failure and why's he reading my disk?
* ZX-14 ABS -08, Finnish guy ^^
  Ignore this member    Click here to visit samin's homepage.
colt
posted September 22, 2012 02:10 PM
Pads are some what new ill try fluid change never heard of cleaning rotor
Beondwacko
posted September 22, 2012 03:34 PM
There have been times that a glazed rotor will be a little grabby. If you scotchbrite the rear rotor, also check the pads. If they had been contaminated then cleaning the rotor will do nothing.
zixxer14
Damn that was Quick
posted September 22, 2012 03:36 PM        Edited By: zixxer14 on 22 Sep 2012 23:39
Use 400 grit wet/dry on the contact area. It will remove any old pad material from the disk. If it's locking up with almost no pressure your brake hose may be bad keeping the fluid from returning from the caliper when you let off the brake pedal.
0.27641296386719 seconds processing time
