BIKELAND > FORUMS > ZX-14.com > Thread: Battery hold down for lsr NEW TOPIC NEW POLL POST REPLY
slacker83
posted September 18, 2012 07:15 AM
I'm getting ready for wilmington and besides dropping my wheels off to get metal valve stems put in I still need to handle the battery hold down issue. Does anyone have any pics or ideas for a gen 1 14? So far everything I have seen seems to be just use some metal bands to wrap around it.
Thanks for your help
Steve
oldkawboy
posted September 18, 2012 09:46 AM        Edited By: oldkawboy on 18 Sep 2012 17:49
Steve,
It depends who the tech guys are, some will make sure you have some straps while others won't check.
This is a picture of how I did mine & I've never had a problem since they started checking a couple years ago.
They won't be able to see with the covers on so after you do it just take a picture of it and carry it with you up to tech.
I'm not racing the event but will be there helping out my son. He'll have a green 14 with a cutdown black tank. If you need any help just holler at me.
Dan
oldkawboy
posted September 18, 2012 09:50 AM        Edited By: oldkawboy on 18 Sep 2012 17:54
For some reason I can't post the picture. Shoot me an email at IGO202@bellsouth.net and I'll send it to you.
Dan
slacker83
posted September 18, 2012 10:31 AM
Dan, I copied the url from the photo and was able to see it thanks for sending me that and I will make sure to take the same photo of mine for the tech guys. I'll have my midnight blue zx14 with illinois plates on it so make sure to say hi if you see me.
Thanks again
Steve
ama573
posted September 18, 2012 11:20 AM
Since the battery is within the frame and the bracket that holds the tray in place is metal you shouldn't need anything additional. Just to be safe I used a large hose clamp to clamp the battery to the tray. Homedepot sells them in the plumbing section for a couple of bucks.
oldkawboy
posted September 18, 2012 11:47 AM
You're welcome Steve, I guess my pictures popped up on their own after a while???
ama573,
I agree with you 100% and have argued that point to no avail, ultimately the tech guys have the final say-so.
Dan
posted September 18, 2012 12:32 PM
At loring this fall, we didnt use anything other than the oem metal cover on the 12. nothing was mentioned about a strap?
posted September 18, 2012 12:39 PM
12R cover serves as the restraint. 14 cover is plastic and needs additional strapping.
Rich
Just havin' fun!!
posted September 18, 2012 04:16 PM
The 14 comes from the factory with a metal bracket running from front to back on the outside of the battery. Why would we need anything else?
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
posted September 18, 2012 04:33 PM
so does mine , why would you need more ? Unless you guys are tossing it out to lose some weight ? No way is the battery going anywhere ..
0.27672910690308 seconds processing time
