BIKELAND > FORUMS > ZX-14.com > Thread: Brocks Pump Gas Map vs Brocks Race Fuel Map NEW TOPIC NEW POLL POST REPLY
Bishopzx12
posted August 16, 2012 04:12 AM
Had a chance to unleash my 14r for the first time at the track. I dont want to post my ET's because i do grudge race from time to time. However i will tell some of the guys on here that i know who are not my local competition the ET's via PM so they can get a better understnading where I am at. On another note all i can say is this MOFO is a beast. All i have is bolt on: Brock's pipe, swing arm, 16/43, ect. Anyways my question is i know MR9 and other race fuels make a little more power i was just wondering has anyone did a comparison to it vs the 89 oct pump gas that brocks recommend. All my runs have been doen with 89 oct in my bike. Thinking of picking some up or any other reccomeneded fuel today and run brocks track map tonight to see if I can gain some E.T. What you guys think?
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
Swiftkart
posted August 16, 2012 08:16 AM
MR12 should gain you .10 to .20 in the 1/4 depending on your weight and riding, I normally see .15 on my 06 zx14 over pump gas.
posted August 16, 2012 12:13 PM
Good luck with mr12.
Lsantana954
posted August 16, 2012 02:36 PM
now are you refering to his Pump gas track map or his street map?
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
cliffrandall
posted August 16, 2012 06:10 PM        Edited By: cliffrandall on 17 Aug 2012 02:23
We found 8 hp on the dyno back in 2003 with MR 9 (it's oxygenated so it's leaner add 4pts of Power Commander fuel to your map). DO NOT leave the race fuel in your motor, pump it out when you're finished with an electric fuel pump on a 12 volt battery combo as shown, then run some pump gas thru. This doesn't apply to VP C12, 14 etc - nor do the gains. The MR fuels are great but it will mess up the injectors if left for more then a few days.
Cliff
BLK ICE
posted August 16, 2012 08:37 PM
Cliff
fuel pump my ass!
Homeland Security has been notified !
Bishopzx12
posted August 17, 2012 03:58 AM
I am running the brocks pump track map
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
Seno
BANNED FOR LIFE!
posted August 17, 2012 04:14 AM
fuel pump my ass!
LOL
dakota9498
posted August 17, 2012 05:09 AM
MR12 is awesome!
2008 ZX14
CraigChrist
BAWLS
posted August 17, 2012 05:19 AM
I seen it... maybe dusty needs a better map to run with MR12 because in dakota's bike that shit is the TRUTH!
60ft-------1.42
1/8th------5.97
mph-------119
Bishopzx12
posted September 17, 2012 03:32 PM
Going, to run some MR12 this week in the 14R. I picked up a fresh can and will be running brocks trak map..
Also picked up one of these
http://www.harborfreight.com/multi-use-transfer-pump-66418.html
I think outside of actually draining the tank and uploading my new map i should be good what you think
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted September 17, 2012 03:38 PM
We got one of them pumps for the shop .. The gas ate it up and it fell apart the first time we used it ..
Bishopzx12
posted September 18, 2012 03:24 AM
Lee did the gad eat the pump or the hose? What do you suggest?
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted September 18, 2012 02:21 PM
If you have a tiger tail you can drain it really quick by unhooking the fuel line off the pump and turning your key on and off
Bishopzx12
posted September 18, 2012 02:44 PM
The pump i used worked great however the hose i that came with it was real sucky. When repeatedly pulling it out to make sure i get to the lowest part of the tank i notice that some shaving were coming off i don’t think much got in my tank but i am so paranoid with stuff like this.
What is a good grade of hose to use when siphoning gas
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted September 18, 2012 03:53 PM
I don't use a pump .. I pull the tank , remove the pump and pour it out .. Yes it's a bitch but after a few 100 times of doing it i can do it pretty quick .. I didn't use the pump on mine because it cut the hose everytime .. I don't want all that crap in my tank .. What i did on one zx14 was tap a hole on the pump flange and install an AN fitting and a hose with a valve .. The hose hung down below the swing arm .. Just turn the valve and drain it into a drain pan .. Better yet run pump gas and no worry about it ..
Bishopzx12
posted September 18, 2012 04:09 PM
Run pump gas are you serious, lol Im just kidding i need MR12 to even try to mimick what you do on 89
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
0.2328040599823 seconds processing time
