BIKELAND > FORUMS > ZX-14.com > Thread: Where is the speed sensor wire located on 14r? NEW TOPIC NEW POLL POST REPLY
Goldwingmann
posted September 17, 2012 10:05 AM
Am trying to install a BACKOFF Brake hold Module...instructions call for installing one of the wires to the bike speed sensor wire.....
Does anyone know where that wire or module is located...possibly near the tranny?
Help....
BobC
posted September 17, 2012 10:18 AM        Edited By: BobC on 17 Sep 2012 18:19
On the 14R ? There are front and rear wheel speed sensors which feed into the ECU. Different from the countershaft nut pick-up on 06/11 bike. Out of the ECU it's a can bus.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
GREYHOUNDMOSES
posted September 17, 2012 01:00 PM
I'd never heard of this but after googling it, it seems like it could be useful.
Unfortunately not on a 14R!
From their ad. **Your Bike MUST have an Electronic Pick-Up Sensor**
The 14R doesn't.
You could try splicing into one of the wheel sensors. Your call!
posted September 17, 2012 01:13 PM
What is it ?
Ninjawarrior1244
posted September 17, 2012 01:30 PM
It is a safety module. I causes the rear stock brake light to flash 5 times, then goes to steady on. Each time you release the brake you get the 5 continuous flashes with each engagement.
Lots of Goldwings have them installed for added rear safety flashing instead of just the stock ON light when you brake.
Speed is fine...but accuracy is Deadly!
posted September 17, 2012 03:00 PM
Oh ok .. Sounds like a good idea ..
venomous_zx
2012 14r - low and long-
posted September 17, 2012 07:13 PM
you mean like this this?
http://www.mymotorcyclebrakelights.com/
this kind of safety light doesnt use a speed sensor just wire it up to your brake switch...
sensei
caps
Satin Black and Gold
posted March 19, 2014 06:16 AM        Edited By: caps on 19 Mar 2014 14:17
Bump. i need to know where the speed sensor wire is.
2010 Ninja 250
2012 Ducati Monster
2005 R6
2006 ZX-14
0.56443500518799 seconds processing time
