BIKELAND > FORUMS > ZX-14.com > Thread: needs some help guys as always NEW TOPIC NEW POLL POST REPLY
colt
if u aint first your last
posted September 15, 2012 08:34 AM
Need to know how to drain radator and I want to run water wetter do fill all the way up with ww or do I use one bottle and some water or one bottle and anti freeze that the help would be great
venomous_zx
2012 14r - low and long-
posted September 15, 2012 09:03 AM        Edited By: venomous_zx on 15 Sep 2012 18:08
fast way to drain radiator is to remove lower hose that connects to the water pump. if you dont know where the water pump is then it is on the lower left side of the bike. cant miss it. looks like a small cylinder with a black rubber hose connected to it. as far as water wetter, i never ran this. i would just follow instructions on the bottle unless someone chimes in that has used it before.
P.s have a good size pan to drain into. Once you disconnect hose the coolant will rush out
sensei
drewzx-14
Andrew
posted September 15, 2012 09:37 AM
I want to run that on my R1.. Let me know how that pans out
2009 Yamaha R1-SOLD!
2013 Zx-14R Green ABS
colt
posted September 15, 2012 11:56 AM
I'm waiting for somebody that's ran it a lot of 14 guys swear by it these 14 run hot and it don't help I leave in Texas
Lsantana954
posted September 15, 2012 11:58 AM
i run engine ice in mines...after running it in my 07 and seeing how cool it kept the bike during BBW last year it was one of the first things i did to my '12
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
cliffrandall
posted September 15, 2012 12:51 PM        Edited By: cliffrandall on 15 Sep 2012 20:51
My suggestion would be to simply take the engine drain screw out and drain the entire coolant system, all while on the side stand. Screw can be found at the bottom of the water pump. Remove the rad cap and have a beer - get a large low container it shoots out pretty good at first......Then button it up, refill and away you go.
This is interesting, of all the stuff we tried nothing worked as well to control the engine heat like running a naked bike! Amazing how much cooler the 1270 ran with all that rad surface exposed and doing it's job.
Cliff
venomous_zx
posted September 15, 2012 01:18 PM
i live in texas too. and yes the 14 runs hot. i filled my radiator with lp coolant. my bike runs a little cooler now. especially while on the expressway my bike runs about 169-172. i tried the drain bolt on the water pump but it drips only. and yes i did remove the radiator cap. seeing
that it has to go across the wheel in the water pump it will take time. the choice is yours colt... lol... what part of texas do you live in?
sensei
posted September 15, 2012 05:09 PM
I have water wetter in mine and I didn't tell a difference.
Read the bottle COMPLETELY. If I remember correctly it says something about only lasting 6-12 months??
Hellmutt
posted September 15, 2012 06:25 PM
Engine Ice in mine, brought down the temp a bar or 2 on the dash LCD gauge. I make sure to swap it out every year, and I have to drain mine every year before winter sets in so it doesnt freeze sitting out in my unfinished/unheated garage ( Ohio winters can get chilly ). Engine Ice does make a bit of a difference in high ambient temps. Not sure what year 14 you ride, but 1st and 2nd gens have a ZX10 front fender conversion that allows quite a bit more airflow to the rad. There's also a 2nd fan mod that can help pull more air through the rad and keep the bike cooler. Wish Kawi would have put 2 fans on these things like the Connies have.
colt
posted September 15, 2012 07:46 PM
Me too mine is fine on hwy just stop light to stop light is gets up there never flashes but still thanks for the help
posted September 16, 2012 12:16 PM
It's fine as long as its not flashing.
colt
posted September 16, 2012 08:04 PM
I know just feels wrong
0.24144196510315 seconds processing time
