BIKELAND > FORUMS > ZX-14.com > Thread: Anyone running a TiForce? On a 2012? NEW TOPIC NEW POLL POST REPLY
lietoome
posted September 13, 2012 06:25 AM
I was hoping I could get some insight on TiForce. Has anyone installed or dynoed one on a 2012? I'm considering buying a used system for a good price, anyone have a map that might work? I'm still working out the details, seller has a map/pc3 for a 2008...not sure how much difference there will be between a 2008 & 2012 when it comes to mapping.
L:2m
BobC
posted September 13, 2012 07:42 AM        Edited By: BobC on 13 Sep 2012 15:46
I emailed them in Japan earlier in the year and at that time they weren't making a system for the 2012 bike so I'll be getting a Brock exhaust. Although they could be by now so it's worth contacting them. They respond to emails in English. (sales@tiforce.com)
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
fullzx12r
French Guy
posted September 13, 2012 08:45 PM
not disponible for 2012
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
lietoome
posted September 13, 2012 08:52 PM
Ive just purchased a full system that came off of a 2008. There should not be any issues. Now I just need to find a map and new PCV.
Than ks for the response. If anyone has a 2012 map, I'd Greatly appreciate a copy to get me by until I can get it dynoed.
L2M
fullzx12r
French Guy
posted September 13, 2012 09:26 PM
is that you are sure that will be assembled over your 2012???
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
lietoome
posted September 13, 2012 09:59 PM
I'm sure it will fit. If not, I will figure something out. lol
fullzx12r
French Guy
posted September 13, 2012 10:24 PM
from tiforce japan :
Hello Oliver,
Sorry for the delay.
According to our tech guy, it does appear the additional deck height on the 2012 ZX14, so our previous pipe will not allow to fit.
sorry, so our previous model can't work right to your new '12 ZX14R.
we will not develop and design the pipe for '12 ZX14R.
very sorry that I can't help you this time.
thanks
Tomoko
sooo ??? !!! ???
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
posted September 14, 2012 02:40 AM
Sounds like of they don't want to make a system for your bike, you need to go with a company that has dedicated the time to do all the R&D for your bike.
bluestar
posted September 14, 2012 03:14 AM
I have the Ti-force on my 2012 14r. The fit is close to the sump but it does work for me.
I am still using the stock map and it still runs fine with no apparent fueling issues.
12 ZX14R SE
11 ZX10R
09 ZX14 SE
WARBIRD
posted September 14, 2012 08:43 AM
How bout some good pics? Surely it would help lietome........the op.......
I'd Rather Be Roadracing.
fullzx12r
French Guy
posted September 14, 2012 10:14 PM
yes, bluestar, we want pictures please !!!
is it the full line, or slip-on ???
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
bluestar
posted September 14, 2012 10:52 PM
It's the full system. I will try to get some pictures today.
12 ZX14R SE
11 ZX10R
09 ZX14 SE
fullzx12r
French Guy
posted September 15, 2012 12:39 AM
so it's the full line of your old zx-14 2009 ?
if you have the price, or the series number
thanks in advance guy
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
bluestar
posted September 15, 2012 06:27 AM
I still have the gen1 - both bikes have the full Ti-Force system. I purchased the latest system from 58 cycle in June - on sale - for $995, including shipping. Heck of a deal. I'll try to get some pictures.
12 ZX14R SE
11 ZX10R
09 ZX14 SE
lietoome
posted September 15, 2012 07:30 AM
Damn, that is a good price. Pics would be great. I really appreciate the information.
bluestar
posted September 15, 2012 10:09 AM
The latest TiForce exhaust for the ZX14 does not have the center tab on the mid-pipe. I did not use this on the 09, since the system is really light and TiForce apparently thought the same and deleted this mounting point. Due to the slight increase in deck height in the 14r exhaust tube number 4
is now very close to the engine sump. I put a temporary (?) shim made of aluminum coated fiberglass mat , folded several times for approx. 1/8 of clearance between the #4 tube and sump.
After adjusting and tightening the system, I left the shim in place in order to insure that the pipe would not contact the sump. The radiator was close to one of the pipes so I added 2 thin washers between the lower radiator mounting point and block. I did add a couple of washers to each of the lower fairing mounting bolts to get extra clearance between the fairing and pipes but his may not be necessary.
12 ZX14R SE
11 ZX10R
09 ZX14 SE
fullzx12r
French Guy
posted September 15, 2012 08:55 PM
okkkk, thanks a lot
tiforce titanium is BEAUTYFULL ! ! ! and very light !
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
lietoome
posted September 16, 2012 06:23 AM
Thank you for the pics and information, Bluestar. This will definitely help me out.
bluestar
posted September 16, 2012 09:18 AM
Good Luck -
12 ZX14R SE
11 ZX10R
09 ZX14 SE
lietoome
posted November 29, 2012 11:05 AM        Edited By: lietoome on 29 Nov 2012 19:10
Parts finally arrived, got a chance to install. No issues as of yet. I did add a couple washers to the radiator support bracket. It wasn't touching, but it was very close. This exhaust sounds amazing. I have a full yosh map for a 2012 until I can get to Dubai & get it tuned. The exhaust is super close to the oil pan, I'm not sure if I will add the exhaust wrap like you did. it's not touching, I may just leave it alone. As for that one hole not lining up(above pic), my exhaust doesn't have that support bracket.
lietoome
posted November 29, 2012 11:11 AM
BTW, Lee, Thank you for the fairing removal Vid...I managed not to break any tabs.
posted November 29, 2012 11:25 AM
You are very welcome .... If the pipe is not touching anything you are good to go ... All the pipe needs is a very small air gap ..
J_ZX14
posted November 29, 2012 12:13 PM
Do you fellas think there would be any fit issues with the high-mount slip-ons on the 14R?
I don't know if i will sell my 2011 14, but I do know I'll be buying a 14R next year, and if the pipes fit, I'd obviously remove them and slap em on the new 14R.
Link to my set-up:
http://www.bikeland.org/board/viewthread.php?TID=68558&FID=27
What do you guys think?
*MARALIZE LEGAJUANA!*
lietoome
posted November 29, 2012 12:32 PM
I don't think there would be any issues at all. I'd do it.
Bently
2012 14r In Blue and no Mods!
posted November 29, 2012 01:19 PM
That pipe is by far the best looking pipe on a 14r that I've seen so far! IMO
0.24270296096802 seconds processing time
