BIKELAND > FORUMS > ZX-14.com > Thread: throttle control NEW TOPIC NEW POLL POST REPLY
captainm40
posted September 08, 2012 08:46 AM
throttle control
I was wondering with the new zx14r could you give it the half throttle mod? The old ziptie around the end of the throttle tube it worked great on my 03 zx9r. And has anyone shorten the throttle at all thanks for all the info you guys give
captainm40
posted September 08, 2012 12:40 PM
Someone knows about making this bike have half throttle I know. Some body has tried it right give me an idea are something
BLK ICE
posted September 08, 2012 02:10 PM
are you asking if we know how to make the throttle only turn 50% to keep the bike from going faster, or are you asking how to make the bike read 100% throttle when only turning the throttle 50%?
GREYHOUNDMOSES
posted September 08, 2012 02:22 PM
Since it worked so well on your zx9r, why don't you try it and let us now how you get on.
Then, perhaps you can tell us what you're on about???
captainm40
posted September 08, 2012 05:18 PM
100% throttle 50% open . Well I'm trying the mod out now only took 10mins . I've only rode it today in full power traction at 2 I weigh 240lb so ive been able to launch it a little better but not sure about a lot of difference. With the traction set at 2 will try it tomorrow with no traction on the cable doesn't rap around tube as 9r did so I'm not sure if I slowed it down are what. I wanted the mod because I put some bigger diameter grips on. So I got to get a hand full all the time because of grips some advice please no one wants to go slower with this bike that I've notice thanks if you can help
izmuk
09 no flies,pvc,muzzy,low.long
posted September 08, 2012 06:56 PM
often i read post a couple times to understand what you guys are saying its not working with this one
mick46
posted September 10, 2012 10:34 AM
I have done a similar mod ... (increasing the diameter of the throttle tube as much as the cables will allow) and have found the rotation of the throttle grip is reduced by about 25 degrees.
It took a bit of fine tuning (with a small file) to get a cam profile that allows a smooth transition from idle to just on the power... but the end result is a very good quarter turn throttle for zero expense (almost ! ).
Only used the bike on the road as yet ( heading to the strip for the first time end of Sept), but much easier to get on full gas... so its got to be good !
I can explain in detail how the mod was performed if anyone wants..
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
captainm40
posted September 10, 2012 11:09 AM
Yes I want I want thanks
toledoUPSguy
An old guy with a new toy
posted September 10, 2012 12:27 PM
I would like the details too
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
TH1RT3EN
Trial And Error Control
posted September 11, 2012 11:49 AM        Edited By: TH1RT3EN on 11 Sep 2012 19:50
http://doublezracing.com/
Rifleman's 1/5th turn Throttle Insert. Works like a charm!!
0.29455304145813 seconds processing time
