BIKELAND > FORUMS > ZX-14.com > Thread: Chain tools NEW TOPIC NEW POLL POST REPLY
Phil
posted August 28, 2012 04:33 PM
Chain tools
Decided to get rid of the master linc clips and chains on the old bikes, who makes a good quality chain breaker / riveter tool????
"Look at Dad, trying to look young again."
zx12mark
posted August 28, 2012 05:33 PM
which ever you buy take a dremel cut off disc to remove the peening on the link you want to split.this will make the job lots easier and make your chain tool last longer.....
zixxer14
Damn that was Quick
posted August 28, 2012 08:35 PM
Motion Pro makes a good one & pins are easy to get. Got mine at Cycle Gear. What he said about dremeling the pin.
Seno
BANNED FOR LIFE!
posted August 29, 2012 04:48 AM
+1, Motion pro tool is descent. Harbor freight does have one, bur I'm sure it's crap...
chrisrok
posted August 29, 2012 05:06 AM
Motion Pro!!! You get get replacement parts for them if you need without any issues.
WARBIRD
posted August 29, 2012 10:26 AM
Best advice you will get right there.............
I'd Rather Be Roadracing.
Obba
posted August 30, 2012 12:48 PM
Sorry a bit thick:
What does this actually mean? "dremel cut off disc to remove the peening on the link you want to split"
WARBIRD
posted August 30, 2012 01:41 PM
Sorry a bit thick:
You should grind down the pins flush with the side plate (or plates ) before you push the pin out with the chain tool. It is much easier on the tool ( and your arm ) if you do it this way. That is very good advice....... Also don't use impacts on the tool. Instead use a wrench or adjustable wrench........your new chain tool will like you for it and last a long time.
0.21420001983643 seconds processing time
