BIKELAND > FORUMS > ZX-14.com > Thread: Tire slipping on Rim NEW TOPIC NEW POLL POST REPLY
Audio
posted August 27, 2012 08:07 AM
Question have you guy ever had the tire slip every pass on the rim an inch to 2 inches?
If so how did you stop it?
I'm running CZ wheels and shinko round slick with 14 lbs on air.
Audio
2008 ZX14 Old Gray CNC-1414 old new CNC ?
2012 ZX14R SE Green CNC-?
posted August 27, 2012 08:22 AM
Mine does that also , i don't lose any sleep over it because after a few runs it stops.. some have used hair spary to stop it ... You might give that a try ...
posted August 27, 2012 09:33 AM
The couple of 180-55 tires I ran moved on the rim. I went back to a 190 and it doesn't do it anymore.
posted August 27, 2012 10:48 AM
Make sure there isn't a bunch of lube on the bead when you install the tire. I have done them using only windex, and that cured the slipping problem. Brock suggested I use the commercial product Ru Glyde, it is supposed to be outstanding.
Quarter Pounder
with Cheese
posted August 27, 2012 12:26 PM
Ru-glyde is the bomb digggity
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
joseph702
posted August 27, 2012 06:21 PM
u buff the tire very lightly with my 3 plastic buffer wheel. makes it a lil sticky and never moved on me even with 8lbs in it
greenbusa
posted August 27, 2012 06:45 PM
I tried the hairspray trick and my tire still slipped but my helmet was harder to take off.....
400+ hp daily driver
BLK ICE
posted August 27, 2012 08:23 PM
Mine moves no matter what tire, 180,190, or slick. I got some "super hold" hair spray for it, but always forget to use it.
By the way, I don't use any lube to mount my tires.
Has hair spray worked for anyone?
greenbusa
posted August 27, 2012 10:09 PM
On a serious note guys, if I had problems with a tire in the past i would clean the bead with glass cleaner to remove any list on the tire, then use it for lube to mount the tire, it has alcohol in it and will dry with no residue. Worked for me.
0.26052784919739 seconds processing time
