BIKELAND > FORUMS > ZX-14.com > Thread: bazzaz question NEW TOPIC NEW POLL POST REPLY
biggmoinc
posted August 05, 2012 01:32 PM
bazzaz question
Going from a pc3usb to a bazzaz fuel management system, As far as starting off with the current map off of the pc3 (brocks)will the values in the cells be the same as the bazzaz unit, looks like the tps/rpm cells are the same,
biggmo@aol.com
mathews
posted August 05, 2012 05:42 PM
No
posted August 06, 2012 04:07 AM
Good luck with it.
I had nothing but headaches with low rpm fueling on both my zx14 and a freinds zx10
Brock didnt have much to say but "no comment" when I inquired with him.
slacker83
posted August 07, 2012 07:43 AM
You might want to look into getting the afm wideband also, I've been using it on my bike with the osr head and the bike has been running great. The only thing I don't like about it is that it doesn't record data under 3k rpm so I need to do some minor adjustments in that range and without a dyno it is hard. Depending on what mods you have done to the bike I might be able to give you a map to try if you go with bazzaz
0.23361802101135 seconds processing time
