astyle96
posted August 02, 2012 04:48 PM
2006 zx14 TRE
Can someone tell me any Info in regards to the 2006 zx14 and what the TRE does for the zx14!!!!!!
astyle96
joel787
posted August 02, 2012 05:02 PM
makes the ECU think the bike is in 6th gear and opens the butterflies faster.... but flies out free and the TRE $80
Danno
posted August 02, 2012 05:22 PM
TRE-timing retard eliminator. Fools the ECU into thinking the machine is always in 6th gear avoiding programmed ignition timing retard in the first three gears. Has nothing to do with the secondary throttle butterflies, which are electronically controlled to open according to primary throttle position, intake vacuum and probably several other sensors. Removing the secondary throttle butterflies gives direct throttle control to the twistgrip.
joel787
posted August 02, 2012 06:05 PM
Edited By: joel787 on 3 Aug 2012 02:08
[link] http://www.bikeland.org/misc/articles/tretest.pdf [/link]
pull the flies, get a muzzy ignition advancer and set at +4 deg
astyle96
posted August 02, 2012 06:45 PM
Thanks for the info!!! My flies are already out , I put the tre on my bike and can tell a big defference without the ignition advancer ! does the ignition advancer realy play a big part in how the bike responds ? Because the bike runs great as is ! im not realy a road racer but I like to have the edge if and when I need it !!!
astyle96
zixxer14
Damn that was Quick
posted August 02, 2012 07:32 PM
There are 2 tre's for the14, one for flies in, one for flies out. I have the flies out tre(006
A) & Ivans map, it improved the throtttle control 100% & eliminated the popping.
From Ivan's site:
TRE-008 - $70.00
2006 - 2010 ZX-14
Increases power below 6000 rpm!
Does not disable speed limiter
Gets rid of part throttle timing retarder in lower gears.
Allows 6th gear (fastest rate in stock ECU) throttle plate opening rate.
TRE-006A - $60.00
2006 & up ZX-14
Requires sub-throttle plate removal & special mapping.
Gets rid of fuel shut-off on decell -
This will allow smooth on/off throttle transitions and will get rid of the annoying pop when the throttle is reapplied.
Our maps are only available with a minimum purchase of $200.00 or more.
