BIKELAND > FORUMS > ZX-14.com > Thread: Lowering strap NEW TOPIC NEW POLL POST REPLY
lazarosp
posted July 18, 2012 01:32 AM
Lowering strap
Hello
I bought a lowering strap kit and I want to ask if I must replace the stock caliper bolts for longer.
BobC
posted July 18, 2012 06:16 AM        Edited By: BobC on 18 Jul 2012 14:25
The answer's yes but the length depends on the type of brackets you are using. I bought some from Ryan Schnitz and they certainly needed longer bolts so I bought four Titanium M10 x 70mm fine pitch socket cap bolts (from Pro Bolt, part number TISC1070F).
I measured the thickness of the bracket and added it to the standard bolt length to determine what I needed, use threadlock too.
If you look here: http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4801159&showprevnext=1 you'll see that the gold brackets come with the correct caliper bolts.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
lazarosp
posted July 18, 2012 10:01 AM
It is 8mm the bracket thickness!
posted July 18, 2012 01:44 PM
I have used both Schnitz and Brocks and used stock bolts ... Never a single problem doing so .. But if you feel the need just get some longer bolts ..
lazarosp
posted July 18, 2012 02:53 PM
Something else about the bolts that used for connecting the strap with the bracket, they have some kind of washers, how much should I tight them?
BobC
posted July 18, 2012 11:53 PM
The bolts normally come in lengths of 5mm increments, so if your bracket is 8mm deep a 5mm longer bolt would do the job. The thread depth is what it is for a reason and personally I wouldn't take any risks with brakes.
Stock wheelbase
0.2990391254425 seconds processing time
