BIKELAND > FORUMS > ZX-14.com > Thread: Anyone have Brock's CT Meg install instructions they can send? NEW TOPIC NEW POLL POST REPLY
epd345
posted June 24, 2012 06:39 AM
Got the used system but it did not come with instructions. Notice there is a bracet in there for something. Anyone with the CT Meg have a copy of the instuction they could send. Thanks
posted June 24, 2012 07:06 AM
Installation info for Brock's products can be found here:
http://www.brocksperformance.com/brocknm/templates/bpp-plain.aspx?articleid=68&zoneid=3
Hope this helps!
kaw-rick
posted June 24, 2012 07:41 AM
whats the bracket look like?
epd345
posted June 24, 2012 02:09 PM
Thanks Shane but they do not have the instructions for the CT Meg listed there. Can you tell me where this bracket goes?
posted June 24, 2012 02:13 PM
Under the rearset mount (footpeg bracket).
epd345
posted June 24, 2012 02:59 PM
thanks again Shane, can I reuse the stock exhaust gaskets or should I replace them. Also there were no header bolts in the kit. I asssume I would be using the stock ones.
posted June 24, 2012 03:23 PM        Edited By: Shane661 on 24 Jun 2012 23:26
I always use new...but this one time, I reused them...my bike had around 100 miles on it. If you do reuse them, and they leak, well...there is the answer. I would use new if I could get them promptly. Just my .02.
If you get new, put the "split" side down, and a little grease will hold them in place while you fit the header.
Stock studs and nuts, but billet spigots/flanges.
epd345
posted June 24, 2012 03:30 PM
Yep I got the billet spigots in the parts. They seem like they actually mount pretty far away from the block. Much further than my Yosh did. I actually reused the gaskets on my Yosh and they never leaked but I will check out if anyone has them in stock and replace. Its going to be a few weeks before I install it as I want to get the PC-V first so it can all be done at once.
posted June 24, 2012 03:33 PM
The nuts will be near the end of the studs, but that is OK...you are going to love this pipe! Also, Brock's can send you a replacement nameplate, if you want to get rid of the scratched one.
epd345
posted June 24, 2012 03:58 PM
I was thinking about getting the whole pipe ceramic coated black including the Can since its so scratched up. I guess I would have to take it all apart to get that done but I think it would look great.
BIKELAND > FORUMS > ZX-14.com > Thread: Anyone have Brock\'s CT Meg install instructions they can send? NEW TOPIC NEW POLL POST REPLY
0.2372031211853 seconds processing time
