mick46
posted June 04, 2012 01:04 AM
The dynojet quickshifter comes with some useful brackets including an adhesive pad with a stud attached which could be stuck on to the sprocket cover.
I drilled the cover and put a bolt through it for my own peace of mind
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
