BIKELAND > FORUMS > ZX-14.com > Thread: busted oil pan NEW TOPIC NEW POLL POST REPLY
chevy454
posted June 03, 2012 11:11 AM
busted oil pan
I was coming from the gas station and heard a little bump, thought it was one of the lowering links scraping the ground so i really didnt pay much attention to it. When i changed gears the rear wheel wanted to spin out, so when i got home i looked under the bike and thats when i saw the oil pan was busted...smh. I was pissed beyond belief when i saw oil pouring from around the drain plug. How easy/difficult is it to change the oil pan? and how much am i looking to spend to get it replaced?
posted June 03, 2012 11:20 AM        Edited By: eklipse636 on 3 Jun 2012 19:21
Call Shannon at OSR (www.osrbikes.com) and he will get you fixed up with drain pan that it's a bit shorter and the drain plus is removed. I lot of guys here have his pans and they work great!
Only other option is find a used pan, but then you could run into the possibility of having same problem.
chevy454
posted June 03, 2012 03:50 PM
Noob question...how will I drain the oil when its time for an oil change if there's no plug?
Lucky14
posted June 03, 2012 04:13 PM
Drain plug gets moved to the back (up on the back side actually) of the pan, where it can't contact the groud .........
02zx12rbob
posted June 03, 2012 05:28 PM
Mine cracked around the plug, sent it OSR. They did a good job. Go to their website and check out the pics.
chevy454
posted June 03, 2012 05:38 PM
I can send the broken pan to them?
posted June 03, 2012 05:47 PM
*** I didn't. Notice it said removed! Lol. I meant MOVED.Stupid iPhone.
Yes you send your broken pan to him and he will fix it.
You also send him your pickup tube and he will be it to the correct length (very important!)
Call them at (317) 523-4049
chevy454
posted June 04, 2012 08:36 AM
i want remove the oil pan myself because i know it cant be that hard, and i called the shop and they said it would be $300 plus parts...smh.
what do i have to look for and is there any precautions i should take?
BrucerZX14
posted June 04, 2012 08:48 AM        Edited By: BrucerZX14 on 4 Jun 2012 16:49
Cold motor. Drain oil. Remove exhaust so pan can be removed. Disconnect sensor on left front of pan. Drop pan by removing all the bolts. Nothing to it.
chevy454
posted June 04, 2012 11:13 AM
the people that i tralked to told me to watch out for the o-ring that may fall. is that part of the oil pan or is it like a gasket?
Juice
posted June 04, 2012 01:16 PM
O-ring sits in between the block and the oil pan. You will see it when you drop the pan down by the corner of the pan with the oil filter.
When i put the OSR pan on my bike the hardest part was remembering what bolts the fearing brackets went through!
2007 Kawasaki Ninja ZX14 SE - 8.74 @ 150 MPH
chevy454
posted June 04, 2012 01:47 PM
Thanks man..as for the oil pickup where id that located?
Juice
posted June 04, 2012 06:16 PM
About center above your drain plug, its plastic and you can see a screen inside of it...
0.24383091926575 seconds processing time
