BIKELAND > FORUMS > ZX-14.com > Thread: Hays clutch NEW TOPIC NEW POLL POST REPLY
zx13r
Capt-America
posted May 16, 2012 04:29 AM
Hays clutch
Anybody put a hays on a 2012 yet?
I know I'm going to have to make a spacer for the inner hub
(from on 08) not sure if the basket is the same yet...
Should have more info next week.
Sposored By:
Kawasaki Sports Center
ShoTime Graphics.com
dakota9498
posted May 16, 2012 06:00 AM
That will probably be a negative. A guy over on Psychobike is building a new 14R and pulled the clutch basket out and compared it to an 08-11 and they are different. The gears are also different along with a couple of other things.
Scroll to almost the bottom of the page and he has pictures comparing the two.
http://www.psychobike.com/forums/kawasaki-zx12r-zx14/95341-2012-14-boost-3.html
2008 ZX14
1badzx12r
posted May 16, 2012 06:12 AM
i don't know what to think on that CP piston ..i'm gonna wait until i hear more info on how they work out ..
BrucerZX14
posted May 17, 2012 01:24 PM        Edited By: BrucerZX14 on 17 May 2012 21:25
My buddy ands I tried to install his Hayes clutch from an '08 into his 2012. No go. The splined output shaft on the 2012 is about 1/2 inch longer. The ring gear was fine. The hub isn't. Hayes is gonna have to rework their set up for a 2012 ZX14.
zx13r
Capt-America
posted May 18, 2012 06:44 PM
As long as the basket was the same,
you can make a spacer for the old inner hub,
I'm thinking. Hopefully next week I'll have a little time
to play with it.
Sposored By:
kawasakijockey
posted May 18, 2012 07:19 PM
MTC has no immediate plans for any clutches either. They are not even currently designing one of any kind(single, multi, or gen2).
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
zx13r
Capt-America
posted May 18, 2012 07:28 PM
When I talked to Tim he said the spacer would be the best bet....
It's the same size as the rear axel. I bought a brake remover/spacer that i never used, I'm going to mill it down and try that.
Sposored By:
Audio
posted May 25, 2012 10:04 PM
I put my 08 basket in my 2012 (its the same for sure, even has the same kawasaki part number ) there is about a 1/2 inch gap on the shaft, but also the front cover also liked about a 1/2 inch from being able to bolt up to the basket. So I'm not sure what to do about that.
Audio
2008 ZX14 Old Gray CNC-1414 old new CNC ?
2012 ZX14R SE Green CNC-?
0.23200106620789 seconds processing time
