BIKELAND > FORUMS > ZX-14.com > Thread: centerstand NEW TOPIC NEW POLL POST REPLY
rugeroid
posted April 24, 2012 03:27 PM
centerstand
Does Kawi sell a centerstand for the 14. I see twisted throttle has one listed for it, but does not say if 14R is the same. I know most of you would not want the added weight, or reduced clearance, but I'm wanting to do some sport touring on mine, and the chain would be a lot easier to lube and maintain with one.
Joe Cool
posted April 24, 2012 03:51 PM
Yes, they sell one for the 14. You need to remove the lower cowling between the frame and the rear tire & it bolts to the same holes the cowling attached to. The lifting support attaches to the left side of the frame and tail support area.
TH1RT3EN
Trial And Error Control
if you go to the European kawi site it shows Kawi part number 999940343 for the center stand for the 2012.
It shows part number 999940125 for the 2006-2011 models.
the usa kawi site has a different number also of 99994-0052 for the 2006-2011 model years.
You should be able to call your local stealership and have them cross reference the part numbers and see which one matches up in their system.
www.kawasaki.eu
cruiserman_83
posted April 25, 2012 02:55 AM
no need to install grab handle. stand has enough leverage that i just gran the sub frame or pasanger peg bracket and stNd it and use my body weight.
zixxer14
Damn that was Quick
posted April 25, 2012 11:22 AM        Edited By: zixxer14 on 25 Apr 2012 19:24
Here's a couple pics with one installed......I used a hose clamp on the left side to hold a rubber bumper for it to stop on when up.
0.21507883071899 seconds processing time
