BIKELAND > FORUMS > ZX-14.com > Thread: Pyramid Plastics Rear Hugger Fitting Problems NEW TOPIC NEW POLL POST REPLY
Goldwingmann
posted April 21, 2012 06:00 AM
Just received the Pyramid Plastics Rear Hugger for the 14r. Beautifully made, and painted......but.......some fitting problems.
Right mount flange had the welded nuts full of paint, so their supplied bolts would not screw into them for the right side frame mount.
Furnished bolt head sheared off when attempting to chase the paint out of the threads, had to mount it into a vise to hold it for thread chasing process.
Right rear mount hole was drilled about 1/4" too low, thus not providing enough clearance for the rotating tire.
Had to mount the left rear plastic flange on the inside of the stock vertical mount stud instead of the outside where it would look better to allow the hugger to flex up, so it would clear the tire.
Nicely made rear hugger, but it should have fit more easily and have more tire clearance for $186.00 delivered.
Ninja
Vmatti
posted April 21, 2012 06:50 AM
It was exactly the same fitting problem with Gen2 Busas too.
So they have not learned about previous cases, shame!!!
ZZR1400 -12
Hayabusa K8 (gone)
shawnski
posted April 21, 2012 07:01 AM
looks really good..
zx12mark
posted April 21, 2012 07:15 AM
why did`nt you call them and tell them to send a ups pick up label .they can refund my money if they can`t get it correct.that`s how you get them to get it right.now they will say you altered it so no warranty if it cracks most likely..
Goldwingmann
posted April 21, 2012 07:22 AM
To answer your question truthfully.....I made it fit. Spent two hours making it work, instead of 15 minutes installing it!
I did not want to go thru the trouble of shipping, returning, and waiting for another unit from UK to be delivered. I can make a small flange if necessary and raise up the rear of the hugger for more clearance. It does clear now, but it is a very close relationship between the bottom of the hugger and the top of the tire.
Just would have hoped that such a nice looking hugger would be better fitting right out of the box with no mounting or hardware issues.
Ninja
shawnski
posted April 21, 2012 07:50 AM        Edited By: shawnski on 21 Apr 2012 16:12
most of the tire huggers are junks and they don't fit correctly.. this is the picture of one on my zx12r and after few days i took it off.. i said hell with that piece of shit!
Shot at 2012-04-21
mick46
posted April 21, 2012 11:18 AM
Here's a hugger for you, fits perfectly and comes colour matched , made by Ermax.
2012 ZZR-1400
Alien Frogskin Green
Brocks CT Meg, PCV & QuickShifter, Brembo M4 Monoblocs, Grimeca 320mm discs, Nitron Race shock, Gilles rearsets , adjusters and TCA axle nut, Supersprox 42T, DID nickel plate X-ring, HEL brake lines, bar risers, shorty levers, tail tidy, Zero Gravity screen, RandG spools and bar ends, GPR V4 damper.... Done !
1999 Hayabusa , stretched lowered and a 60 shot !
Rajun Cajun
posted April 21, 2012 01:46 PM
Sorry u had that prob! I had proobs with a diff product from some other place.
Candy Thunder Blue 2006 ZX-14, +1 rear, RoaringToyz blocks, windscreen spikes! (VERY SHARP! DO NOT TOUCH!!!!)
Time lost can not be retrieved! Its not dumb to ask questions. Rajun Cajun
posted April 21, 2012 02:49 PM
I would like to see a bigger without a chain guard for guys with extended swingarms.
0.31457090377808 seconds processing time
