Mongoose 1108
posted April 20, 2012 10:40 AM
no power at ignition, battery new, everything is dead, alarm works, battery at 12.6. Suggestions, fuses all good, is there a relay at coil that can blow?
2009 ZX14
Any idea where to go to next.
Battery is brand new 12.6
Scorpio alarm works lights flash when activated.
No console lights or anything when key is in the on position.
Both fuse boxes are all good nothing blown.
Is there another relay at coil that can be bad.
Pissed off so a good time to ask questions.
3000psi and falling
posted April 20, 2012 10:57 AM
I think that alarm has a ingition dissable, look up the wireing diagram for the alarm at scorpio's website. One you locate the alarms ignition dissable wire check the conection, Id bet there is a good chance its the problem. Depending on where it was tied in, it could cause these symptoms.
Hurricane
posted April 20, 2012 11:05 AM
Edited By: Hurricane on 20 Apr 2012 19:06
Alarm is probably connected directly to battery thats why it works. I would check fusable link.
1badzx14
08 Turbo zx14!!!
posted April 20, 2012 11:18 AM
Also there is a main fuse behind the battery.
1badzx12r
posted April 20, 2012 11:24 AM
quote: I think that alarm has a ingition dissable, look up the wireing diagram for the alarm at scorpio's website. One you locate the alarms ignition dissable wire check the conection, Id bet there is a good chance its the problem. Depending on where it was tied in, it could cause these symptoms.
what he said..i've had nothing but issues from these junky alarms
WARBIRD
posted April 20, 2012 11:26 AM
Yes sir..........what 1bad said.........toss the alarm........
I'd Rather Be Roadracing.
samin
posted April 20, 2012 02:03 PM
Edited By: samin on 20 Apr 2012 22:04
"No console lights or anything when key is in the on position."
Scorpion ignition disable cuts all power from the dash too?
Just asking.
Br, SamiN
*Who's General Failure and why's he reading my disk?
* ZX-14 ABS -08, Finnish guy ^^
TH1RT3EN
Trial And Error Control
posted April 20, 2012 02:18 PM
quote: "No console lights or anything when key is in the on position."
Just asking.
Br, SamiN
Yes it does.
There should be an inline fuse as well on the alarm. Double check it. You should be able to bypass the ignition kill on the alarm. It should be a little square box with 2 blue wires that tie into the ignition. I would bypass it first and go from there.
What version of alarm are you dealing with? do you know?
Bad in Black
posted April 20, 2012 02:31 PM
I have alarms on 2 of my 3 bikes....my 14 has a scorpio alarm. The hi-jack ignition disable feature is nothing but a problem waiting to happen, I don't have that hooked up on either bike. But overall the alarms have been great, stopped MANY people from messing with my bikes, and kept quite a few kids off of them. I've caught quite a few folks (including kids with parents watching) just leaving my bike as I came out to check after my alarm remote went off. I can't imagine what would've happened without the alarms. I'm pretty anal and installed my alarms well, no problems in 5 years with either system.
Me likey
Seno
BANNED FOR LIFE!
posted April 20, 2012 04:41 PM
Funny thing about the Scorpio alarms is you can disconnect both plugs going into the "brain" and the alarm is disabled.... I have had one on both of my 14's... Never an issue with Scorpio using the no cut wiring harness and the paging feature is very nice.
shawnski
posted April 20, 2012 06:03 PM
How do you know battery has voltage? Does your instrument panel works or totally dead?? Have u done any work to the bike recently or just went out?? I had previous experience with tip over sensor and once with kickstand switch... Just saying in case it is not alarm..
