BIKELAND > FORUMS > ZX-14.com > Thread: Cam sensor ? NEW TOPIC NEW POLL POST REPLY
Oz Booster
posted April 15, 2012 12:37 AM
Cam sensor ?
Hoping someone here can help me figure out whats happening with my 08 zx14
Turned it off yesterday then several hrs later tried to start it and now getting a error code 23 cam sensor short circuit or incomplete circuit , the sensor has 43k ohm resistance through it , and i have continuity from the wires to ecu
Is there something i'm missing ?
The FI code comes up immediately i key on, gauges don't even finish cycling
SixSixoh6
posted April 15, 2012 02:11 AM
internally shorted sensor it sounds like
samin
posted April 15, 2012 04:02 AM        Edited By: samin on 15 Apr 2012 12:03
Did you check all sensor wires + connectors for damage? Resistance should be between 376 and 564 ohms.
43k sounds like damaged sensor pickup coil.
*Who's General Failure and why's he reading my disk?
* ZX-14 ABS -08, Finnish guy ^^
  Ignore this member    Click here to visit samin's homepage.
oldkawboy
posted April 15, 2012 04:46 AM
Same thing happened to my son's 14 after swapping to an aftermarket ignition rotor. Same code would display but would not always fire off.
If you're running a different advancer, install the oem part and try it.
Dan
1badzx12r
posted April 15, 2012 05:15 AM        Edited By: 1badzx12r on 15 Apr 2012 13:17
i been down this road a few times ..always turned out to be a grounding issue .. except on 1 zx12 it busted the cam chain what was lucky or just freaky ..it did it in a spot where the motor could turn without hitting the valves..
Oz Booster
posted April 15, 2012 02:09 PM
Thanks for the suggestions will do a bit more checking today
manual has me confused a little, says to set to 10x and resistanse should be 400-460 ohm, is that 4000-4600 or 400-460 ?? Samin from your answer i will check again and see if i missed a 0. and consider it 400-460
Dan that sort of thing is what i'm wondering ? std advancer but a piggyback controler hardwired in , and it has a dodgy crank position pin in the piggyback connector ,kept backing out , waiting on a new loom to fix it , but thought i had it fixed firm and has tuned ok till now, will look further on that circuit too
And i will check the gnds too out wih the sandpaper , with piggyback, water inj pump ,wideband etc this has a lot of current moving around , and i am using several chassis mount points
Oz Booster
posted April 15, 2012 11:53 PM
Its 432 ohm i missed the 0. in 0.43k ohm
Pretty sure nothing is wrong with the sensor or wiring to the cam sensor , what bugs me is the fault code is immediate at key on, if i induce other faults it takes a second for self diagnosis at key on , and can't even find a crank sensor fault if i unplug that
.02 ohm gnd resistance was the most i found
samin
posted April 16, 2012 10:44 AM        Edited By: samin on 16 Apr 2012 18:45
OK so sensor itselfs sounds good, so as grounding.
If harness is all good, it could be ECU problem.
Do you have any mods on bike?
Have you checked battery terminals and voltage?
Have you tried just crank it ? http://www.zx14ninjaforums.com/messages.cfm?threadid=1898D40D-D56B-84E2-1BED30D960ADC01F&page=1&#13
Oz Booster
posted April 16, 2012 01:34 PM
Turns and turns, no life , going to put a car battery on jumpers and try turning it over lots and see if i can get the response like in your link
Yep , turbo with piggyback controller, all working fine untill i started it to show friends, just idling and small revs , then turned it off, came back several hrs later and get this error code...
going to revisit the piggyback connection(AEM-FIC) to the crank sensor too, tests fine at the AEM , and have a bypass jumper to eliminate the AEM , but will verify i have not got a cracked wire at a solder join ,
Oz Booster
posted April 16, 2012 04:34 PM
just cranking it worked thanks Samin
Thanks to all for your suggestions too
Now i can finish the last few tuning runs and maybe see what it can do in the 1/4 on the weekend
0.21699404716492 seconds processing time
