BIKELAND > FORUMS > ZX-14.com > Thread: What gas to use on the street??? NEW TOPIC NEW POLL POST REPLY
GixxerJohn
2012 zx14R SE
posted April 14, 2012 04:38 AM
Per kawa i was using above 90 which in new jersey is 92 octane. I hear guys always saying to use 89 octane,on the old 14 i used 87 but the new one it says to use over 90. I just street ride should i just be safe and use 92 or is 89 better. Thanks in advance!!!
2012 ZX14R SE
1badzx12r
posted April 14, 2012 05:02 AM
get the green nozzle .. yellow nozzle works great too..them black nozzles are junk tho..
codyc_13
posted April 14, 2012 05:04 AM
Street riding only, put 92 in it.
8.97 at 149mph
Goldwingmann
posted April 14, 2012 05:09 AM
Brock recommends 89 with his header system....it works great!
GixxerJohn
2012 zx14R SE
posted April 14, 2012 05:50 AM
Great all different answers!!!
2012 ZX14R SE
1badzx12r
posted April 14, 2012 06:06 AM        Edited By: 1badzx12r on 14 Apr 2012 14:09
how hard is it to put gas in a motorcycle..use what you dynoed with and gained 15rwhp..
http://www.bikeland.org/board/viewthread.php?TID=66630&FID=27
kawasakijockey
My 07 says to use 90 but in the summer it runs on 92-93 and winter I run 89. The bike doesnt run as good on the street with 87, runs a bit warmer. I recommend 89, 92-93 for street riding.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
BIG BLUE_ZX14
posted April 14, 2012 06:07 AM
I use a blend of paint thinner and crisco.
2007 Blue ZX14 Gone...
oldkawboy
posted April 14, 2012 06:27 AM
I've got an '09 but have the head cut to bump compression. I run premium on the street because I ride two up alot and also ride in the mountains around here.
While I don't lug the bike I don't always keep it spinning and like the higher octane just for insurance.
Momma Kaw might be conservative and are playing it safe but they are the folks who design & build them, I'd have no issue follwing their advice.
Dan
GixxerJohn
2012 zx14R SE
posted April 14, 2012 02:26 PM
Thanks guys.....except 1badzx12r
2012 ZX14R SE
gilberjj
Friend of Fast
posted April 14, 2012 02:54 PM
I used premium (92) or 89. I couldn't ever tell a difference between the two even after 12k miles.
joseph702
posted April 14, 2012 03:16 PM
89 my bike ran warmer and would ping on hott days put 93 and ran better no ping
SixSixoh6
posted April 14, 2012 04:08 PM
my bike runs best on Jack Daniels
1badzx12r
posted April 14, 2012 04:14 PM
try some Everclear mixed 3 TO 1 with your JD
epd345
posted April 14, 2012 05:06 PM
Since I run around town lugging the thing most of the time I run 93 Octane with a little seafoam every few tanks. Keeps thing flushed out nicely.
kawanator
posted April 14, 2012 06:25 PM
Well, I suppose if Kawa says 90, then 92 is the safer option to prevent detonation and the risk of holes in pistons.
Am I right in saying the higher the compression, the higher the octane rating that is required ? And the ZX14r does have a high compression ratio.
posted April 14, 2012 07:00 PM
I run 87 all the time. Haven't had a problem yet
rspauldi
posted April 15, 2012 02:18 AM
eklispe, i find it hard to believe that u are running 87 octane with a compression ratio of 13.1 or 13.5 which ever is tthe case. Are u asking for trouble? Why not pay a few eextra pennies to protect urself from the deadly detonation? Yes, you can get by for awhile but misshift or hit the rev limiter and u cud be asking for trouble. I really don't understand these posts advising u to run a high compression motor on low octane fuel... It's simply foolish....
posted April 15, 2012 02:47 AM
Im by far not the brightest person here, but I've has a zx14 since 2006, and I've got THOUSANDS of passes on the two bikes I've had. *knock on wood* I've never had a motor problem. I've never had a detonating problem. I live in south ga where the heat is unbearable. I raced all day with 87 octane, and won. So guess what? I'm going back to the manufactures cup today with 87 schell in my tank.
posted April 15, 2012 02:48 AM
If it's foolish, he needs to run 93. What the fuck is he doing asking a stupid question?
cls
posted April 15, 2012 03:25 AM
I ran 92/93 the first few tanks then dropped back to 89 w/no problems. I run the Seafoam twice a year. I use the Lucas upper end treatment (almost) every tankful.
GixxerJohn
2012 zx14R SE
posted April 15, 2012 04:51 AM
Hey eklispe there are know stupid questions just asking for peoples thoughts,and u can run 87 in the old 14,but IF U ARE THAT STUPID to run 87 in the new 14r,well no need to answer to my posts because noone will listen to you anyway
2012 ZX14R SE
1badzx12r
posted April 15, 2012 05:09 AM        Edited By: 1badzx12r on 15 Apr 2012 13:09
i like this guy he's more fun than a box of rocks .. if i remember correctly the OLD zx14 had a sticker on the gas tank saying not to run less than 91 TOO
shawnski
posted April 15, 2012 05:17 AM
I have always put 87 on my last three ZX14 and no problems..
shawnski
posted April 15, 2012 05:21 AM        Edited By: shawnski on 15 Apr 2012 13:25
By the way gixxerjohn don't get too excited if someone wants to use 87.. it is his bike not yours.. u can put ethanol if you want..
All times are America/Va [ This thread is 5 pages long: 1  2  3  4  5     Next» ] < Previous Thread     Next Thread >
0.22255897521973 seconds processing time
