BIKELAND > FORUMS > ZX-14.com > Thread: Clutch cover NEW TOPIC NEW POLL POST REPLY
Rob7R
More balls than brains.
posted April 10, 2012 06:17 PM
Clutch cover
Hey guys,
I've done some searching through previous threads, and I checked in the service manual but I wanted to make sure before I start. Is replacing the clutch cover a straight forward task? The manual makes it look like you just remove the bolts and take off the cover. Then to re-install you put silicone and a new gasket put the cover on and replace the bolts. Is it really that simple? Is there any kind of booby traps inside that may fall out if I'm not careful? Should I drain the oil, or is it fine on the side stand? Any info you guys can give me will be much appreciated
Thanks!
Rob
Current bike- 07 ZX14 black with D&D cans, PC3, 43t rear sprocket, 6 inch extensions, roaring toys lowering links. Muzzy Bonneville Pro, TRE Velocity stacks, Puig DB windscreen, Sargent seat, Heli-risers, and throttlemeisters.
Rich
Just havin' fun!!
posted April 10, 2012 06:23 PM
Keep it on the side stand and you don't have to drain the oil. I've had mine off a couple of times and haven't replaced the gasket yet. Just be careful with it.
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
posted April 10, 2012 06:27 PM
It is a very easy task. No silicone needed. Sometimes you can even get away with reusing your gasket.
Worse case buy a new gasket. Don't overtighten the bolts and squish the gasket out.
Rob7R
posted April 10, 2012 06:28 PM
Thanks guys!
edszx14
posted April 11, 2012 02:51 PM
Roll your front tire on a 2 x 6 or 2 x 8 and lean the bike over on the kick stand. This way the bike will lean a little more and you won't lose any hole. I have reused my clutch cover gasket many times just don't overtighten the cover bolts.
Ed
edszx14
posted April 11, 2012 02:59 PM
I am a spelling idiot. I meant that when the bike is leaned over you wont lose any 'oil' not any 'hole'. Sorry about that.
Ed
0.41975402832031 seconds processing time
