BIKELAND > FORUMS > ZX-14.com > Thread: auto shift box NEW TOPIC NEW POLL POST REPLY
killer 14
posted April 05, 2012 07:26 PM
auto shift box
Hey guys I'm interested in a auto shift box by mps but don't know with what setup I should go with mps has more than one. Could I still shift with the horn if I pull the chip? Also with the auto shift do u have to fill the bottle separated or could u use the air shifter pump ? Little confuse but really like it lol thanks guys
posted April 05, 2012 07:36 PM
You can do both ... you can have a shift button and the auto shift .. I have mine set up that way ... You can use co2 or N20 or a cheap air pump .. If you use N20 or CO2 you need a DOT high pressure bottle ... If you use a pump you can use a low pressure bottle ...Low pressure you will have to pump it up after every run .. CO2 or N20 in a one pound bottle you can get 400 + shifts before refilling it ...
killer 14
posted April 05, 2012 07:43 PM
wow 400 shifts sweet! So any mps set up will do?
posted April 05, 2012 07:54 PM
Best to call MPS and tell them what you have and what you want it to do and they will hook you up with the right kit....
killer 14
posted April 06, 2012 02:58 PM
will do thanks
LeonidasZX14
posted April 06, 2012 04:57 PM
Don't go with the auto shift IMO. I had horrible results and pulled the shift pill. I've been thumb shifting ever since. On a great track auto shift kicks ass but on any other it is not dependable.
09' ZX14
killer 14
posted April 06, 2012 08:05 PM
good to know thanks
0.27408790588379 seconds processing time
