BIKELAND > FORUMS > ZX-14.com > Thread: zx14 Temp ? NEW TOPIC NEW POLL POST REPLY
tking
posted March 15, 2012 04:46 PM
zx14 Temp ?
I'm new to the zx14 I've always had busa's and gsxr but I really like my 14. I just got it a month ago and milled the head a little and put engine ice in it. I've rode it a few times now and noticed that it has 6 bars on the temp gauge. After 5 minutes its at 3-4 bars and at lights it gets to 5 and even was at 5 for a little while when riding? Is this normal? If so is there anything I can do to get it a little lower?
Wheelie
Old Man
posted March 15, 2012 04:51 PM
make sure the radiator is full.
wee
tking
posted March 15, 2012 04:53 PM
It's full and it was only 70 out when I was riding?
Wheelie
Old Man
posted March 15, 2012 04:55 PM
you sure, after draining and filling mine always holds more.
You piped?
wee
Wheelie
Old Man
posted March 15, 2012 04:57 PM
wee
after riding around it takes more.
wee
venomous_zx
2012 14r - low and long-
posted March 15, 2012 05:00 PM
temps rise while you at stops..... once you get moving they drop... they really drop when you are on expressway/freeway/interstate cause of the speed... you force more air to the engine. but if they keep rising to high then something may be wrong. make sure your full in your radiator
sensei
tking
posted March 15, 2012 05:01 PM
I've checked it before not in the last week but a couple times when I stop it loses a little from the drain
Wheelie
Old Man
posted March 15, 2012 05:04 PM
stock exhaust?
wee
tking
posted March 15, 2012 05:05 PM
muzzy m14
Lou D
posted March 15, 2012 06:08 PM
These machines are the fastest vehicles on the planet. They run a little hot. GET RID OF THE STOCK EXHAUST. Lou D
  Ignore this member    Click here to visit Lou D's homepage.
BrucerZX14
posted March 15, 2012 06:11 PM        Edited By: BrucerZX14 on 16 Mar 2012 02:12
Mine has a Competition SS head and 47mm throttle bodies. Most I ever see is 4 bars. Track or street. Make sure your fan is turning on. Mine is on after the 4th bar has been on for a bit.
tking
posted March 15, 2012 06:16 PM
I don't have stock exhaust, I have full muzzy system and milled head with degreed cams. Runs great but always 4-5 bars after just a couple minutes? Fan comes on at 4th bar. Does someone still make a second fan kit for it?
COOTER
posted March 15, 2012 10:13 PM
You can add the 2nd fan from a concourse 14 and spice it in to your stock fan they will come on at 4 bars but will cool faster or you can run it off a switch but then you have to remember to turn it on and off!
BobK
2012 ZX14R SE
posted March 16, 2012 04:49 AM
Just because the overflow tank is full doesn't mean that the radiator doesn't have some air in it. I would get one of the vacum kits on the market and re-do the filling procedure as you sure seem to be running too hot. I had an 07 with a milled head and some other goodies and it would never get as hot as you are saying. Radiators can be pesky things to deal with.
tking
posted March 17, 2012 08:58 AM
Well I found my problem. When we installed the motor somehow the 2 small hoses at the top of the radiator were switched. The top one was going back to the t-stat instead of to the overflow tank. Switched them today and road for over an hour and the only time I hit 4 bars was at a 4 minute stop light and it went right back to 3 after I started riding again.
cls
posted March 17, 2012 09:33 AM
I love it when it's something simple. I'm hoping this bike won't run hot like my '06 tended to.
0.24828314781189 seconds processing time
