BIKELAND > FORUMS > ZX-14.com > Thread: 2012 ZX-14R ECU Flash for Flies Out without a PCV NEW TOPIC NEW POLL POST REPLY
Greggy
posted February 28, 2012 09:03 PM
This (below) from Flash-Tune when I asked them in an earlier email about the possibility of an 2012 ZX-14R Ninja ECU reflash to handle opening the butterflies (much) earlier than stock and fixing the resultant lean condition that opening (pulling) the flies creates. Basically with a properly flashed ECU there is no need to physcally pull the flies and it also negates the requirement of a Power Commander after doing so. Could be good for some of us???
We are still working on our Mitsubishi ECU equipped Kawi coding but our interface will get you complete control of the butterflies as well as ignition and fuel mapping
Customer Service
Flash-Tune Inc.
www.flash-tune.com
sales@flash-tune.com
1338 South La Brea Ave
Los Angeles, CA 90019
Phone: (888) 543-6302
Local: (562) 314-6284
2012 ZX-14R ABS - Spark Black - Two Brothers V.A.L.E. Carbon slip ons P1X tips - Powerbronze DB screen.
1990 ZX-10 Ninja - Megacycle stainless steel mufflers - gear-sack rack - tinted screen.
zx12mark
posted February 28, 2012 09:11 PM
berry interesting
BobK
2012 ZX14R SE
posted February 29, 2012 06:25 AM
We definitely need to let these people know how many owners are out there that will buy their service once they get it done so they understand there is a big market for their product.
Greggy
posted February 29, 2012 07:12 AM
Agreed.
Having a professionally developed ECU program to suit a range of different bike configurations is a fantastic idea and would have a big market. If Flash-Tune can provide pre-configured programs that suit the real world (i.e. 99% of bike owners) I can't see them failing. They don't need to worry too much about custom race programming as those guys will always want/need to fine tune everything themselves to suit their race conditions, and it's likely they'll stick with mods like physically taking the flies out and using Power Commander devices etc.
Now for starters I suggest Flash-Tune provides a 2012 ZX-14R ECU with a completely re-programmed 'F' power mode to simulate having the secondary butterflies out yet still providing correct fuelling (no lean spots). That would wake the sleeping giant for sure! In other words if you want FULL power you run it in F power mode and enjoy the 1441cc motor as it was meant to be, but if you are feeling lazy or tired you can switch to L power mode and take it nice and easy. It would be a reason to actually use L power mode, because right now F power mode is very forgiving in its stock form.
I've ridden a 2010 ZX-14 with the flies out and its TOTALLY AWESOME, and makes my stock 2012 ZX-14R feel rather lazy and unwilling under 4,000rpms compared to the older model without the flies.
Message for KHI engineers: When in F power mode please don't hold anything back!!!
Greggy
Goldwingmann
posted February 29, 2012 07:49 AM
What is the costing of this ECU Re-Programming?
NInja
BobK
2012 ZX14R SE
posted February 29, 2012 08:35 AM
NInja
Once they get their programing in place it will be $150. to flash the ecu and free updates if you make mods to the bike. They will be able to flash a power commander map directly into the ecu so a tuner could actually hook up a power commander to your bike, create a pc map and then flash the ecu and remove the power commander. The very best of all worlds.
cls
posted February 29, 2012 09:35 AM
Sounds like the cat's meow. I guess you have to remove the ECU and send it in? I guess you can do that?
BobK
2012 ZX14R SE
posted February 29, 2012 09:59 AM
Yes, it is under the seat with simple plugs. Must remove tool box and then pull ecu out and then disconnect the plugs.
Oz Booster
posted February 29, 2012 12:48 PM
Greggy a mate of mine in WA does suzuki flash tuning (ECU editor) and will be getting the
kawasaki stuff from flash tune when its available , very familiar with the technology as they do both car and bike , pretty sure they have done the mitsubishi ecu's in evo's etc before
i'll send you the info when there doing the Kawi
cls
posted February 29, 2012 04:20 PM
I've messed w/the PC's and all but no ECU work. And mechanicing is far from my strong suit.
Much obliged for the help. I hope this option comes through. That'd be convenient, clean, and cheaper.
robrooter
posted February 29, 2012 04:22 PM
Oz Booster is there any going to be on this side of aus thanks mate.
Ride it, Respect it, It can an will bite you when you least expect. /smilies/smile.gif" border=0>
venomous_zx
2012 14r - low and long-
posted February 29, 2012 09:18 PM
Im verrrry interested in this. By all means keep us all updated
sensei
Oz Booster
posted February 29, 2012 09:55 PM
Rob i'm sure a few places will get them to compliment the already available Suzuki, and now Yamaha tuning,
Although i'm not a commercial business I will get one , and i could be fairly sure about at least one in Sydney and another near Gympie, and one in Adelaide
robrooter
posted February 29, 2012 10:38 PM
sounds good just have to wait an see thanks Greg.
Greggy
posted February 29, 2012 11:25 PM
I guess we just need to work out of the Australian model ECU (for our ABS equipped ZX-14R) is any different to the USA model ECU without ABS, but I'd say the ABS function is probably disjoint from the engine management. Someone might be able to confirm this?
Greggy
Oz Booster
posted March 01, 2012 01:26 AM
If its like the US and AU/EU busa differences you cannot mix and match , the AU/EU has an immobiliser the US does not , so flashing an AU ecu with a US flash will not run unless there is an option to disable the security
Probably need to get an Aussie ecu to them do they can download it and have our version available in the database
Vertigo99
posted March 01, 2012 03:53 AM
Would the ECU reflash be available for pre-2012 14's? I'm gettling close to pulling the trigger on a Brocks pipe and I'd like to do it without the need for a PCV.
08 Atomic Silver
BobK
2012 ZX14R SE
posted March 01, 2012 06:07 AM
More than likely once they have the ecu figured out and get any 14 in for tuning they will be able to flash all 14s.
blue07
posted March 01, 2012 06:25 AM        Edited By: blue07 on 1 Mar 2012 14:29
"I've ridden a 2010 ZX-14 with the flies out and its TOTALLY AWESOME, and makes my stock 2012 ZX-14R feel rather lazy and unwilling under 4,000rpms "....hmmmm.interesting.Even without the Guhl flash...my 2012 feels WAY stronger at 4K than any previous version with no flies.
I can only imagine just now what lower gearing will produce
Greggy
posted March 01, 2012 08:08 AM
Removing the flies makes a HUGE difference to the ZX-14, I can only assume it will make a similar difference to the 2012 ZX-14R. A few guys here have done this mod, but no one has really given a definitve review on what its been like, or if its really worth it.
Personally I liked the way the (older) ZX-14 performed without the flies as the throttle response at low RPMs is quite scary but addictive at the same time.
I think the difference on these new 14R's is mainly going to be felt at under 4000rpms, as once you get near and above that engine speed, the new 14R is definitely way stronger.
Greggy
blue07
posted March 01, 2012 08:17 AM        Edited By: blue07 on 1 Mar 2012 16:20
I had my ECU flashed to open those secondaries just off throttle.BEFORE 4K.I can tell ya...the KTRC set on '1' doesn't always kick in like it does with the stock secondary opening point.So it's virtually 'flyless'.I can't honestly say..."she'll rip yer arms out'...no...because they also recalibrated the ignition settings.In fact....in all honesty....she has a slight 'bog' right off throttle.IF I open er wide open...or close to it.Soon as she hits about 2K...she takes right off though....and will loft immediately...before 4K.
I don't remember now if that 'bog'(and it's very very slight)was there before the flash.If I added throttle(a bit) at the bottom,and popped the clutch...I know she'd blast off VERY WELL.I try not to do that!Not all the time anyway
cls
posted March 01, 2012 08:35 AM
Last I spoke w/Brock's folks they were saying it was looking like the 'flies removal wouldn't help out the '12 but they had not yet finished their testing at that time. I haven't seen or heard of any updates to that.
0.25624895095825 seconds processing time
