BIKELAND > FORUMS > ZX-14.com > Thread: valve cover leak NEW TOPIC NEW POLL POST REPLY
cas15
posted February 19, 2012 03:52 PM
valve cover leak
i used the search and they say to use a washer under the bolt . does any one know how thick the washer should be the bike only has 2000 miles thanks
  Ignore this member    Click here to visit cas15's homepage.
conn-e-rot ninja
posted February 19, 2012 04:33 PM
here you go
http://www.zx14ninjaforum.com/messages.cfm?threadid=91DAF396-D56B-84E2-1CB7DC17E5343386
2007 zx14
cas15
posted February 19, 2012 06:02 PM
here you go
wat is that the part number or some thing
conn-e-rot ninja
posted February 19, 2012 06:54 PM
It's a link to website with a how to on fixing your leak
2007 zx14
cas15
posted February 19, 2012 08:51 PM
found it thanks I'm gonna give the m10 washer first then go from their thanks
conn-e-rot ninja
posted February 20, 2012 06:00 AM
becareful not to over tighten the bolts
2007 zx14
Rook
posted February 20, 2012 04:25 PM        Edited By: Rook on 21 Feb 2012 00:36
LOL I remeber the days when I never touched a computer not so long ago.
that's a link
you click on it .....like this
thanks for posting the link, BTW. the tutorial also has a few links to other tutorials that you may wish to look at. If you can get by without properly removing the heat blanket, that will cut the job to 1/4 the time.
posted February 20, 2012 04:36 PM
shimming the valve cover bolts with a washer works great, dont ask me how I know
Rook
posted February 20, 2012 07:25 PM
Mine is up on stands. No leaking like last Winter. The washer trick didn't work for me but it helped. Hope the break in action allowed that leak to seal up completely.
I torqued to spec. As mentioned, DO NOT try top fix this by tightening because the aluminum threads in the head will strip pretty easy and then you really are supposed to get a new head--according to Kawi.
I believe the best thing to do us get the newand improved head gasket and replace the washer/rubber rings on top as well as the head hole gaskets inside. If that doesn't fix it as it should be done, you know the problem is not parts and you know the only thing to do is throw washers in there.
cas15
posted February 20, 2012 07:40 PM
that's a link
thanks good post
0.22234702110291 seconds processing time
