BIKELAND > FORUMS > ZX-14.com > Thread: EVIL arm install help NEW TOPIC NEW POLL POST REPLY
NINJA12
posted February 18, 2012 08:49 PM
My evil arm is about 1/2 shorter across the mounting neck.
With the spacer that came with the the arm on the left side, and the adjuster on the right
cranked almost all the way in, the arm slides around way too much.
What am i doing wrong or should i have gotten two spacers.
One sheet of instructions would have helped.
06 zx14
posted February 18, 2012 09:01 PM
You have to use your factory spacer also .. You will also need the spacer tube out of your old swing arm .. On the lower bearing where your links go you will need to ream the shit out of that hole to get the bearings to fit .. It is a real nicely done arm but it does need instructions ... Hope that helped..
NINJA12
posted February 18, 2012 09:33 PM
factory spacer on the left new spacer on the right? they are close to same size.
I did use the spacer tube.
Thanks I'll give it a try tomorrow.
NINJA12
posted February 20, 2012 10:47 PM
Thanks Smokin
I got back to the bike today and got the arm installed.
Looks great.
0.30671501159668 seconds processing time
