BIKELAND > FORUMS > ZX-14.com > Thread: Any 14R Owners in LA? NEW TOPIC NEW POLL POST REPLY
BobK
2012 ZX14R SE
posted February 02, 2012 08:12 AM
Flash-Tune is looking for a ZX14R to use to do ECU flashing and tuning so the rest of us can then use their services. I would think they would give a deal to the first person to bring them their bike. Come on guys lets get this done.
http://www.flash-tune.com/?page_id=9
Lucky14
posted February 02, 2012 08:37 AM        Edited By: Lucky14 on 2 Feb 2012 16:38
We can only DREAM!!!
For $350 or so, they claim that you can do the following to an R1, for example:
You can directly import Power Commander .djm fuel maps!
This Interface allows you to easily adjust the following!
Ycc-t Throttle Restrictions
Engine Braking
Fuel Map Bias
High Load Fuel Maps (with PC3 and PC5 map importing)
Low Load (cruising) Fuel Maps
Fuel Injector Proportioning
Ignition Timing
Immobilizer Function
Cooling Fan Temps
Rev-Limiter Control
Remove Top Speed Limiter
YCC-I RPM Control
Idle Speed Adjustment
ECU Based Quick-shifting
and new features are added regularly...
.................... on the other hand, think of the damage that could be done by an unskilled user ..............
BobK
2012 ZX14R SE
posted February 02, 2012 10:17 AM
Yes, but in the hands of a qualified tuner it would be great.
0.22049999237061 seconds processing time
