BIKELAND > FORUMS > ZX-14.com > Thread: Air shifter set up 2012 ZX14R NEW TOPIC NEW POLL POST REPLY
posted January 29, 2012 11:06 AM        Edited By: smokinZX14 on 29 Jan 2012 19:39
A few pictures of where and how i set up the air shifter and controlls ..
Low pressure gauge ..
MPS auto shift location ... It has to be right where i put it so the auto shit RPM chip doesn't hit the seat .. The chip fits up into one of the empty spaces in the bottom side of the seat . Power wire is tapped right into the old tag light wiring .. So now the kill box has a fused power line ..
High pressure adjustable Regutator
Air Ram ..
20 OZ Co2 bottle on the swing arm ..
Hope this might help you guys to give your some ideas on setting up your air shifters ..
posted January 29, 2012 11:07 AM        Edited By: smokinZX14 on 29 Jan 2012 19:28
Over ride button.. Made my own button bracket ( didn't want to spend 130.00 bucks from a MPS )
I used a heavy duty trans brake button from MR gasket .. It has a coiled cord and works well when turning the bike .. You can't see but the button is held in place with Hook Lock from Radio Shack ...No holes to drill , just peal and sick to the flat buttom part of your turn signal switch ... It not like velco , it's so strong you need to use a screw driver to split it apart .. Unlike Velco you just Can't pull it off easly .. Thanks to Wrongway ( Roy ) for turning me on the the Hook Lock stuff .. Trust me , you put this stuff on your seat and your butt and you will never get off the bike !!! It's that strong !!
posted January 29, 2012 11:11 AM
I really like that regulator setup, very nice...also, nice pipe!
Does the mps setup tap into the 4 coil wires?
posted January 29, 2012 11:14 AM
You can ... MPS has a plug and play right to the coils ... I didn't do that , i tapped right in at the ECU wires at the rear of the bike ..
codyc_13
posted January 29, 2012 11:28 AM
Where do you run you low pressure gauge from? Do you have a "T" in the line somewhere? Mine is directly on my regulator, but I like where you have yours.
8.97 at 149mph
posted January 29, 2012 11:33 AM
I used a "T" right before the shift solenoid ... My shift solenoid is right next to the coolant bottle ..
codyc_13
posted January 29, 2012 11:37 AM
Ok that's what I was thinking, definitely a better setup than mine, as I have to get off the bike to check the pressure.
8.97 at 149mph
kaw-rick
posted January 29, 2012 12:49 PM
watch out for line crimping in the neck. been there done that.
posted January 29, 2012 04:52 PM
Thanks Rick i will keep an eye out for that .. I have a pretty big loop going into the stem so it should be ok .. But you never know ... Thanks ..
posted January 29, 2012 05:12 PM
Lee, do you have any pics of how you ran the line to the guage up front?
posted January 29, 2012 05:23 PM        Edited By: smokinZX14 on 30 Jan 2012 01:24
No sorry i don't .. But i will take some and post them Monday .. I ran it along the ram air tube ... down under the ram air tube and up and over the left side of the Rad .. Zip locking the air line to the bottom part of ram air clamp of the ram air tube so not to get to close to the heat of the Rad .. From there over to the lower hole in the steering stem and up the the gauge .. I have pleanty of slack so you can go lock to lock on the steering and not pull or bind the air line ... The trick as i found out on my zx10 was to keep it away from any hot engine parts .. It will swell up and pop if to close the main engine heat .. The Gauge is from MRE and fits nice and tight in the stem nut , so it doesn't move around .. I put one wrap of electrical tape around the nut that holds the air line to the gauge and that gives the gauge a snug fit into the stem nut ..
posted January 30, 2012 12:12 AM
Very, very clever gauge placement, good on you!
hmmmmmm.... where do i get "Hook Lock"???
Seno
BANNED FOR LIFE!
posted January 30, 2012 01:45 AM
Thanks for sharing, nice job!
Jeffrey Peck
Old School Racer X
posted January 30, 2012 06:44 AM
Nice clean job Smokin. You can wrench on mine any time bro. Good looking install job.
Peck
Kawasaki Proud!
posted January 30, 2012 09:13 AM
Peck,
warp back 10 years at the Texas Shootout; you were my hero. N/J
I hope all is well with you these days, you are one FAST mofo!!!!!!!!!!!!!!!!!
Karl
posted January 30, 2012 10:04 AM
Radio Shack has the Hook Lock ..
1badzx12r
posted January 30, 2012 10:05 AM        Edited By: 1badzx12r on 30 Jan 2012 18:06
how in hell is that gonna work ...i think you need to get the bottle mount on the tire side of the arm .. or you gonna have to flip the bottle upside down in the same spot..
posted January 30, 2012 10:08 AM
how in hell is that gonna work ...i think you need to get the bottle mount on the tire of the arm .. or you gonna have to flip the bottle upside down in the same spot
??? Why would i want the bottle upside down ?? All i have to do to remove it is twist the thumb screw and the bottle comes right out ..
1badzx12r
posted January 30, 2012 10:23 AM        Edited By: 1badzx12r on 30 Jan 2012 18:24
cause your bottle gonna be shove up your crack when you put a load on that swingarm.. look at the clearance you got between the undertail and the top of your bottle
posted January 30, 2012 11:21 AM
Well you are wrong .. You can tell from the picture , it's full 7 inches before it's hit the undertail ... The bottle also had tons of ground clearence.. Now maybe just maybe if you put a 1200 pound dumbo on the bike it might hit the undertail ...
Look at this picture and you can see the bottle leans back giving it pleanty of room for the rear of the bike to come down and hit nothing ..
1badzx12r
posted January 30, 2012 12:16 PM
optical illusion
posted January 30, 2012 01:17 PM
optical illusion
Yup ...lol
Slow14_Fz1
posted August 11, 2012 08:17 AM
SmokinZX14
Is the coil wiring the same on the new 14R as it was on the old 14?
08 zx14 Turbo 17lbs 8.84@159 spinning
2012 zx14r NA 5.93@118 9.30@147 best 1.37 60'
Slow14_Fz1
posted August 13, 2012 03:52 PM
Bump
Could someone please help with the wiring for the coil wires on the 2012 zx14r that's all I need everything else is done I have the SM ordered but I'm tring to get the auto shift box finished before this Friday.
posted August 13, 2012 04:01 PM
Bump
I don't remember the wires i used but i did it at the wires at the ECU and not the coils .. PM Wee he has a thread here somewhere on bikeland that gives you the colors ..
0.21641993522644 seconds processing time
