BIKELAND > FORUMS > ZX-14.com > Thread: daytona shift light help! NEW TOPIC NEW POLL POST REPLY
fullthrottlekaw
posted January 10, 2012 09:53 PM
just purchased a daytona sl1 shift light / data logger and need some help locating some wires does anyone know where i can find a 08 zx14 wiring diagram?
or does anyone know where to locate:
rpm siginal wich i assume is neg side of coil?
tps sensor
vehicle speed sensor
thanks any help would be appreciated
dakota9498
posted January 11, 2012 04:59 AM
You can tap into all of these at the ECU. Have you downloaded the manual from this site yet? If you haven't, do that it is a huge help, it has all of the wiring diagrams and what color wires to look for. If you don't want to tap into these at the ECU, you can catch the TPS sensor and coil wire in the loom right off the side of the engine and the speed sensor can be tapped into before the gauge cluster.
If I remember correctly the speed sensor is blue/yellow, TPS yellow/white, and just use the number 1 coil wire and you should be in business.
2008 ZX14
fullthrottlekaw
posted January 12, 2012 12:19 PM
thanks alot man downloaded that manual and found the diagram BIG help!
CajunBoyz
posted January 12, 2012 12:24 PM
Let us know how it works out, Inetrested in the rpm,02,& TPS data logging?????
0.21552896499634 seconds processing time
